Thread: HELP: Custom 3-Wheeler with TB05E
    Oct 2007
    Ohio
    6
    Question HELP: Custom 3-Wheeler with TB05E
    This weekend I came across a custom trike with a disassembled TB05E. The engine is marked TB05E-6050307, from what I have found I believe it is a 200cc (192cc) from an '84 ATC200ES Big Red. Does that sound about right?
    The engine mount was specifically designed for the engine from what I can tell, I attached a pic. The rear shaft mounts to the drive shaft for the rear wheels through a swivel type piece that connects the two shafts together.
    What is the largest replacement engine that could utilize the same mounts?
    Where could I locate a diagram of the engine with an exploded view and a rebuild manual? What about a rebuild kit? I have boxes of pieces, but am not sure if I have everything.
    I appreciate any help.
    Steven
    Attached Thumbnails Attached Thumbnails Stealth_Trike_08.jpg   Stealth_Trike_Engine_Shaft.jpg   Stealth_Trike_Engine_Side.jpg
    Southern MN
    1,875
    bikebandit.com will have a lot of diagrams to look at. Try a search for service manuals on the top right search bar, and look for the user named , you will likely find an on line manual you can use there. Some parts for the rebuild can be purchased from sites like rockymountainatv.com , denniskirk.com , and ebay. There are many other sites you can order parrts from as well. Good luck!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Sep 2007
    100mi west of Chicago
    3,582
    Must be from an 84 Big Red since 82-83 was chain drive.
    Rob
    Oct 2007
    Ohio
    6
    Quote Originally Posted by Yamaha_Rules69 View Post
    I appreciate it, Jon.
    I found the manuals here: http://72.52.143.80/~trikes/Manuals/ATC%20manuals/
    I am not quite sure how I am suppose to search for a complete rebuild kit, I have not been able to determine which exact year and style the donor was for the engine...
    Steven
    Oct 2007
    Ohio
    6
    Quote Originally Posted by rdlsz24 View Post
    Rob
    Great catch Rob
    I meant 84, the 83 was a typo...
    I based it on the ATC200ES Big Red info I found here: http://www.3wheelerworld.com/1984HondaSpecpage.shtml
    ATC200ES Big Red
    Frame number JH3TB0554EC300001~
    Engine number TB05E-6000001~
    Engine type 4 stroke, Air cooled
    Steven
