Results 1 to 13 of 13
Thread: oil leaking from exhaust?
    85200xrider's Avatar
    85200xrider is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    Cranston RI
    293
    i got my 85 tri-z and im completly new to 2 strokes. im just curious....
    i got oil leaking out of the head...where the exhaust pipe is. my brothers buddy says its normal....
    is it?
    and if it isnt...how do i fix it?
    bonkers_200s's Avatar
    bonkers_200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Middletown, NY
    393
    New gasket should do it. Either its just old and past its time, or someone had it off at one time and put it back on.
    If you can't fix it with a , its an electrical problem.
    85 ATC 200s--Ratted out and not running at the moment
    86 ATC 200x--All stock other than the handle bars
    85 ATC 250es Big Red -- Just got new rubbers and she wants to ride!!
    04 Suzuki LTZ250 quadsport - It was a decent price and I'm a raging idiot.
    Mar 2007
    Texas
    5,045
    make sure no one over ported the head and port the exhaust right up to a thin wall of then top head chamber.
    ________________
    https://www.mikesatvfix.com
    Feb 2009
    Cranston RI
    293
    so it is normal? where do i get a gasket because i do know i need a new one? i know i need new springs too...could i use any spring from the hardware store?
    Feb 2009
    Cranston RI
    293
    i dont kow if it matters but im running belray mc1 50:1 with 93
    Mar 2008
    Tug Hill
    1,282
    do you need springs because there isnt any? that would make it leak...
    http://cgi.ebay.com/ebaymotors/Yamah...Q5fAccessories
    scottp597's Avatar
    scottp597 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2009
    Lowell, IN
    153
    I would say that you should pick up a new gasket and oring, and make sure you have all the springs on. Should fix it
    Feb 2009
    Cranston RI
    293
    i have 2....but the p.o had one hooked on the top where its supposed to...and the other one stretched all the way to the motor skidplate....
    so its normal for oil to come out of the head?
    scottp597's Avatar
    Apr 2009
    Lowell, IN
    153
    Quote Originally Posted by 85200xrider View Post
    I don't think im reading you, so I made this for your assistance.
    Oil may leak out of the "exhaust" which can be fixed with the gasket/orings. The red line is where your head gasket goes, oil should not leak out of there at all or there is a problem. Don't mess with the head.
    Jan 2005
    RI
    2,530
    tri-z's are mofos to seal up at the exhaust/cylinder....
    get the silencer off, take the pipe off, get the new gasket and spacer thingy, then clean everything up really nice.
    put a fair amount of rtv on the cylinder where the pipe fits, put rtv inside the pipe where the spacer goes, put rtv inside the spacer, put the gasket in, a little more rtv, then throw the pipe on the bike with springs, get the silencer all mounted up and let it cure for an entire day.
    there is a high temp black silicone that ihave found works the best. cant think of the name off hand but its made by permatex.
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Rittman, Ohio
    6,276
    is it?
    Your buddy is correct. If a TriZ does NOT leak at the exhaust it is abnormal.
    Feb 2009
    Cranston RI
    293
    ok sounds good...looks like ill be buying some gasket an oring and springs
    oregon
    78
    i just boughta billet flange with 2 silicone o-rings from sandstorm racing for my trx250r and it made a huge differance. feels like i gained more power and snappy too
