Thread: Need Help!
    May 2009
    hutchinson ks
    7
    Need Help!
    just blew up my 86 250r atc i purchsed a 1988 250r 4 mill crank for it yesterday and later on i was told the 88 had a longer rod? if this is true how will i get to work on my 86? space up jug? please some one help
    na
    5,702
    Call Wiseco.They will tell you what you need.
    There are tons of threads on this, I believe you just use the 88 Long rod piston to make it work..
    I found this info here, apparently just get the 88 piston kit and you are set.
    http://www.3wheelerworldforums.com/s...2&postcount=24
    Proudly NOT a member of
    "Team on the Teat"
    May 2009
    hutchinson ks
    7
    ok, BUT, im putting on the esr 310 cylinder kit on it will i need to change anything on that piston size or anything?
    na
    5,702
    ESR Should just send you the piston for the long rod motor to fit the 310kit.
    You better ask them, and tell them what you have for a Crank and rod set-up.
    "Team on the Teat"
    May 2009
    hutchinson ks
    7
    Talking
    awesome thanks for all the help!
