Well as my luck would have it my old Tecate 4 is back in my neighbourhood. And now I am fixing the motor. The previous owner told me that the orange silicone was top notch 40$ a tube cnd. Looks like high heat gasket which does not go good with gas. Anyways. the motor has a small but could be serious noise in the tranny. I guess while running in netural the trannys has a clicking noise. Now I know these machine has bad bottoms ends. with motor out and turning the sprocket you can feel a slight clicking through the out put shaft. Could this be a bent or wore out shift fork? Spacer missing?
, its an electrical problem.
