A lot of times the axle will fuse with the inner bearring race from moisture getting into the hub and causing rust. That is a tough job sometimes. One thing you could try to do is heat up the outer hub on both sides, and try to hit the axle through. You may want to use somthing to protect the threads, such as a piece of wood or somthing. I have had one that just simply wouldnt move, so I had to rip out the rubber seal on each side, and get a
, punch and chizel and break the bearrings out, then got the axle out. Its a litttle easier from there, but remember to remove the outer bearring races if you end up breaking the bearrings. Heat is most times your best choice. Good luck.
81, 85 Yamaha Tri Moto 125
83 Yamaha Tri Moto 200 x2
85 Yamaha Tri Z 250
84 Kawasaki Tecate 250
84 Honda ATC 70
85 Honda ATC 350X
84 Honda ATC 250R
(2) 84 Honda ATC 200x
82, 83 Honda ATC 185s
81 ATC 200
Lots of other parts and bikes
