Results 1 to 15 of 20
Thread: Liquid 250R headgasket issue
    Micahdogg's Avatar
    Micahdogg is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2007
    Illinois
    378
    I took apart a running/good condition 250R motor to paint it nicely. When I reassembled it I made sure to clean the mating surfaces well with solvent. I slapped a new headgasket on, made sure the studs were in good shape, even bought new honda nuts for the head. Torqued it to spec and now after about 5 hours or riding I noticed that coolant is slightly weeping from the front and it's between the head and cylinder.
    I took the tank off, put a socket on each bolt and got a little more stank torqued down on each nut. Went for a ride, and damnit...it's still weeping. I think it's much less of a leak, but still there. Is it possible that the gasket was already breached and now it's junk? Because I cannot imagine putting any more torque on each nut.
    Micah
    P.S. I didn't use any copper HG spray or anything...just slapped the gasket it there.
    (if you click this stuff, you will see pictures of this stuff)
    2001 Indian Scout
    2011 KTM 250SX
    1986 ATC250R
    1989 Thunderbird SuperCoupe
    2006 F150 Crew
    Nov 2004
    OH.
    2,487
    Might wanna try decking the head. I could be warped. I've done several 250R motors and never had any leakage. And I've never used any sealant. Just the gasket.
    Micahdogg's Avatar
    Dec 2007
    Illinois
    378
    I would think it would have been warped on the old motor as well, but seemed to seal fine on the dirty motor.
    2001 Indian Scout
    2011 KTM 250SX
    1986 ATC250R
    2006 F150 Crew
    Aug 2004
    Phoenix
    1,226
    Its not warped if it was fine before you took it apart. What brand of headgasket did you use? And yes putting it on dry is the correct way.
    4 Strokes are NOT the wave of the future!
    Micahdogg's Avatar
    Dec 2007
    Illinois
    378
    I think it was a K&S gasket kit? Some kind of initials like that. Even though dry is the way the factory calls for it....has anyone used copper HG spray on them just for some added seal?
    2001 Indian Scout
    2011 KTM 250SX
    1986 ATC250R
    2006 F150 Crew
    Aug 2004
    Phoenix
    1,226
    Oh brother that tells me alot. Those K&S gasket/seal kits are the worst quality. I've seen those leak always. Go get a OEM head gasket or Vesrah and put it on dry. You should have no more problems.
    Micahdogg's Avatar
    Dec 2007
    Illinois
    378
    Glad to hear it. I used the cylinder base, kicker seal, clutch cover and water pump gaskets as well. Knock on wood, those have been ok.
    2001 Indian Scout
    2011 KTM 250SX
    1986 ATC250R
    2006 F150 Crew
    Aug 2004
    Phoenix
    1,226
    Def keep an eye on the cylinder base. The other ones aren't as critical, but go with only OEM for seals and oem or vesrah for the gaskets in the future.
    Pafrig's Avatar
    Pafrig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2009
    ALASKA
    278
    over torque head bolts. good idea.
    Phoenix, AZ.
    6,719
    I've used copper spray on a 250r head gasket before. Never had any problems but that was with a quality head gasket to begin with.
    Aug 2004
    Phoenix
    1,226
    Doug, the thing is with the oem, vesrah, and some cometic? gaskets is they are a multi level steel gasket with a rubber viton sealant coated on both sides already on it. If you add sealant on top of that it can reduce the sealing property.
    Micahdogg's Avatar
    Dec 2007
    Illinois
    378
    I wasn't aware that OEM was a MLS gasket. I definitely don't recall this K&S gasket being MLS.
    2001 Indian Scout
    2011 KTM 250SX
    1986 ATC250R
    2006 F150 Crew
    Oct 2007
    Minneapolis mn
    4,067
    Ah... A bottle of BAR'S LEAK and good as new... (extreme sarcasm) I like bars leak as much as jb weld
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Try a Cometic gasket. If that dosent solve it get the head checked, it's probably warped.
    TF 07,08,09,10,11,12,13,14!
    Micahdogg's Avatar
    Dec 2007
    Illinois
    378
    Well, I picked up a Cometic top end gasket kit and installed the new MLS headgasket this weekend. I rode it around the block and got it good and warmed up....wouldn't you know, no more leaking coolant. It's been sitting in the same spot in the garage and been fine for a couple days now.
    NOTE TO ALL OTHERS, DO NOT BUY K&S HEAD GASKETS - THEY ARE JUNK!!!!
    The old K&S headgasket was about 3 times as thick and a made out of traditional type material (kind of soft on each side). I don't know what was so bad with it, but things just didn't seal up good with that piece of junk gasket.
    Thanks for the tips everyone.
    Micah
    2001 Indian Scout
    2011 KTM 250SX
    1986 ATC250R
    2006 F150 Crew
