Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: Liquid 250R headgasket issue
    Nov 2002
    Chezzetcook Nova Scotia
    1,838
    Quote Originally Posted by Thorpe View Post
    Ah... A bottle of BAR'S LEAK and good as new... (extreme sarcasm) I like bars leak as much as jb weld
    How well does bars leak work? Seen it work in cars but was told it will clogg up the smaller motors. Ive had major problem with head gaskets too and am tired of buying head gaskets.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Micahdogg's Avatar
    Micahdogg is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2007
    Illinois
    378
    I can't think of a time when I would ever resort to using any "rebuild in a jar," "smoke-b-gone," "compession-b-back," or bars stop leak. It's just less work in the long run to fix it right.
    (if you click this stuff, you will see pictures of this stuff)
    2001 Indian Scout
    2011 KTM 250SX
    1986 ATC250R
    1989 Thunderbird SuperCoupe
    2006 F150 Crew
    Nov 2002
    1,838
    I have about 6 blown head gaskets in all different kinds of blow outs. 200+ dollars to keep blowing it up.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Quote Originally Posted by Tecate250 View Post
    Bar's stop leak won't stop this problem at all, you have existing problems elsewhere.
    TF 07,08,09,10,11,12,13,14!
    Micahdogg's Avatar
    Dec 2007
    Illinois
    378
    Case in point. If I followed this logic, I would have simply added coolant every so often to my three wheeler and not tried to fix the problem.
    I can't knock you for buying headgasket #2, or even #3.....but at that point you should have realized the headgasket isn't the problem. Something else is causing it to blow and you need to investigate.
    2001 Indian Scout
    2011 KTM 250SX
    1986 ATC250R
    2006 F150 Crew
