Results 1 to 3 of 3
Thread: No Spark...Got new CDI box...Still no spark?
    Minnesota
    31
    Well I ordered a new CDI box for my 1984 200ES. Had power going in to the old one but no power coming out. Plugged in the new one and still no spark. Now what should I replace?
    May 2009
    Brampton, ontario
    686
    spark plug.
    Looking for some smaller style tires like the r's have, just 2 back tires. pm please.
    Southern MN
    1,875
    You sure there is spark coming off the stator? Yeah, you got a new plug, right? All wires connected and no breaks? The next thing I would check is the Ignition coil. You can test it with a multimeter if you have one. You need to test for OHM's resistance. There is a primary side and secondary, or plug wire side to the coil. Check the manual to find the correct readings on it. It could also be your spark plug cap or wire, which can be tested also. Good luck. ---- Jon.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
