Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 62
Thread: aldochina's 86ATC350X
  1. #31
    Lewiston, N.Y.
    1,479
    Great collection of parts!! Holy Moses! I still am so jealous that you found that, i have always wanted an 86 versus the 85 but im still thrilled with my deal!! Cant wait to see more!
    Jim
  2. #32
    HONDALUVR's Avatar
    HONDALUVR is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2007
    ARKANSAS
    250
    Will The 350x Headlight Assembly Work On A Atc 250r ?
    IT'S A TEAM GREEN THANG !!!
  3. #33
    Oregon
    2,471
    Nice colletcion, Let us know what's going on SALE !
  4. #34
    Mar 2008
    EastGreenbush, newyork
    3,494
    easy guys, as of right now I dont know what i will do, will most likely keep most parts for now, I have 5 headlight assemblies, a few exausts, so I can get rid of a couple of those. i have to go through the rest of my parts and see what I can weed out. I'll let you's know
  5. #35
    Mar 2008
    3,494
    cleaned carb today, wasnt that bad, cause it had been drained. outside was a mess!!, exaust was missing carbon cleanout cap, made new one, and drilled and tapped where old bolts were snapped. axle is about ready to come out, so I can asess the damage from blown bearing. I could tell the right rear wheel had never been removed before!!(SWEET) airbox and plumbing removed for cleaning, filter cage is kinda rough but i got a nicer one, it had a homemade filter, decent job on it acually. Threw it in the trash. I will clean it up good while its apart. Of course i broke the 3 header gaurd bolts removing that to get at the exaust clamp they are like freaking butter!! So those will have to be fixed. I want to remove the header, but i DO NOT want to break any exaust studs!! judging by the amount of mud caked on there for the last 2 years they wont be easy, I tried the one that looks almost new, and it didnt seem like it wanted to come. so i left it for now. should I try after i run it while its hot? I have been hitting it with sea foam all day. Who has a good recomendation for this, i'm sure tons of you have done it. I hope to get it going tomorow, I will post some more pics+progress.
    It pisses me off when i think how sweet this thing would be if he had only spent 15 min washing it before he put it away!! I'll get her back to her old glory!!
  6. #36
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    PB Blaster and a wire brush, also try warming the engine then spray with the pb blaster. be patient and they will come out.
    Nothing to ride... for now
  7. #37
    Mar 2008
    3,494
    heres a shot of the carrier, I think I can salvage it, but im gonna throw this spare in for now, the adjusters on the one are in much better shape, so hopefully i can revive it!!
    the outer race , or most of it is still in there
    als wondering if there is any problem using this 85 axle/sprocket, while I get the other cleaned up. will the bolts on the back of the sprocket work with the 86 carrier.
  8. #38
    Mar 2008
    3,494
    heres a pic of my other x, its an 86, all there, starts, and runs good, The guy I bought it from was not honest with me, he was asking 1800.00 for it, I almost didnt buy it, he said it needed nothing really. didnt get to ride it but around his one time, he ended up taking 1400.00 for it, and threw in 2 extra sets of wheels, so I went for it. After getting it home and riding it and getting into it, this is what i discovered: needs axle bearings, 2 lower exaust studs are broken, rear master cylinder leaks, (when full brakes work great), will need a clutch soon, in tight trails,stop/go it squeals a bit. has good comp, and tons of power, but definately smokes. has metal tank, but after a weel it sprang a leak, so I bought a plastic one. That is being completely honest. It has basically sat since I got it, awaiting rebuild, other than a few romps around the property here and there. I have a 350x front fender for it, has a rare hondaline black seat cover!! I have 1550.00 into it, and would let it go for 1200.00, would really make a nice machine with a little tlc. I think I obviously paid two much for it, but I was exited and nieve i guess at the time, I think 1200 is fair, with the 2 sets of wheels and maybe some other bits.
  9. #39
    Mar 2008
    3,494
    heres a few shots of her broken down a bit
    just built this shed, lots more to do in it yet, but the exterior is done, gonna post some better pics of it in the shed thread!! check it!! 3 on top 3 on bottom!! I know shoulda made room for more!!
  10. #40
    Mar 2008
    3,494
    well i spent most of today on the 3- wheeler, got the rear end all back together, like new, put the carb I had cleaned back in, cleaned airbox, petcock, the tank is absolutely perfect inside!! Took the plug out cleaned it, couldnt seem to find a new one although i know i got em. turned on the gas, unfortunately it was pissing out the overflow!! but I kicked it 3 times no choke and it fired right up Sounded very loud!! since it sat with all that mud caked on the motor, it must have rotted the header seals, I could see sparks when giving it some throttle and looking closely!! leaking by header pretty good I would imagine. Unfortunately befor I put the cleaned up and oiled chain back on I figured I would remove the case saver and clean the gunk and dirt from the slider and drive sprocket area. Well to my surprise I was disgusted to see that the stator cover was busted right in front of the sprocket, about a quarter size chunk right on the edge is cracked and pushed in about an 1/8" leaving a slight gap between the cover and case. How big of a deal is it if this was run this way for awhile. there has to be some dirt and stuff in there. So no oil flows through there right?, Just houses the stator? I'll snap a pic of it later! So now I have to get a carb rebuild kit, get the headers off without breaking the studs so I can replace the seals, get the stator cover taken care of, and some new rear brake pads and she should be good to go. I want to ride it a for awhile before i tear it all down for a very thorough go through!! Whats a good carb kit to get for these, and does anyone have a decent stator cover they could spare for reasonable $. Looks like it will be awhile yet before I get to enjoy a ride on her, but I did do a quick lap around the yard and boy I cant wait
  11. #41
    Feb 2009
    michigan
    2,387
    nice
    cool story,and cooler 350x.miss mine.you should build one to ride and continue to amass parts for a trailer queen.youll have two
    1985 ATC 250R
    . Team Red Trike
  12. #42
    Lewiston, N.Y.
    1,479
    Good to hear your making progress!! You asked about a carb kit and here is the link from the one i used on mine. Exellent kit!!
    http://cgi.ebay.com/ebaymotors/Honda...Q5fAccessories
    you need to post a video of it and get more pics up!
  13. #43
    Oct 2007
    Minneapolis mn
    4,067
    This is the carb kit I used on my 86 X... Worked like a champ...
    http://www.denniskirk.com/jsp/produc...d=&mmyId=10271
  14. #44
    Apr 2003
    Bay Area CA.
    2,638
    Wow the cleaning made a HUGE difference lol nice X! congrats
    1985 350x
    1985 atc70
    2006 ltz400
    2017 z125pro
  15. #45
    Mar 2008
    3,494
    got the moose kit coming, dont think I need it now, but good to have on hand. I realized the o-ring I used on the float bowl drain screw was to thick, it wasnt allowing the screw to seat properly. so it should be all right now. Just waiting for some parts so I can get it back together. trying to clean all sorts of little stuff while i'm waiting, this thing was filthy, filthy!! I thought the seals on the header were bad, but all that caked on mud rotted the one side right through. I had a real nice spare, just had that redish brown baked on mud all over it. the oem paint underneath locked pretty good, so I wanted to try and salvage it, but that cooked mud is tough as nails, I tried a few things, and nothing would cut it without using something abrasive, so I ended up painting it. came out sweet!! Hopefully the next pics I post I will have it all back together, and riding it.
