Thread: just picked up a 250sx.....?????
    rebel33382 is offline At The Back Of The Pack Arm chair racerFirst time rider
    New Orleans, LA
    201
    it was only 160 bucks, runs and shifts great, no rear fenders, no seat, no brakes of course. here the deal, the swingarm bearings are GONE! This trike litterally "rocks." heres my question, the driveshaft has alot of play in it, pulled the boot back, not real happy about that. I have a 250ES frame and swingarm. can I use the driveshaft from the 250ES?
    not the last question about this project......!!
    1984 200ES first Shaft driven big red with reverse!
    85 Big Red 250ES with a rebuilt top end!
    New Orleans, LA
    201
    anyone?! I love how the front end on this bike pops up, nervous about the driveshaft and swingarm bearings.......
    racerxxx's Avatar
    racerxxx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Pennsylvania
    383
    Driveshafts are different, replace the swinger bearings. Not a tough job. If the end of the driveshaft that goes into the diff is rusty and grooved, you'll be moving into the rebuild of the rear diff. A clean driveshaft will only be ruined going into that old pinion seal. Not to hard but requires some special tools that can be made. Look at "The curious case of Jim's SX" thread.
    1985 Honda 125M (My first Trike--Still have it)
    1986 Honda 250SX
    1981 Honda 110
    1982 Honda 110
    1986 Yamaha YFM80 (Sons quad)
    Past rides: 1983, 1984 200X, 3--1985 Kawasaki T-3
    1987 CR-80, 70's vintage XR75, RM 370
    Houston
    77
    How hard is it to replace that rubber boot on the drive shaft
    racerxxx's Avatar
    Oct 2008
    Pennsylvania
    383
    Quote Originally Posted by Jbird5363 View Post
    Not hard, just a little time consuming.
    To replace the boot you need to remove the swing arm. There is a swing arm pivot bolt on the right side of the frame, it's covered by a plastic cap. You will have to remove it before you can remove the pivot bolt. Start flooding it now with penetrating oil. There is a special tool required, but you can also get it with a drift punch---you just have to be very careful. Then remove the pivot bolt with a 17MM hex socket(allen wrench). While your in there that deep I'd do the swing arm bearings as well. ANd obviously you'll have to remove the brake lines,vent tubes and shock.
    1986 Honda 250SX
    1981 Honda 110
    1982 Honda 110
