So, my exhaust on my zinger is pretty filthy internally... Whats he best way to clean up the gooey carbon build up?
Propane torch always does it quick and easy. Just burn the carbon till a bit red then scrap away with a flat head screwdriver.
Remove all the warning label and let nature take its course
sand blast it
Avatar: 1986 250SX with a 350x front end. Almost done.
Feedback thread: http://www.3wheelerworld.com/showthr...-for-Coaltrain
If it's gooey at all, you'll find sandblasting to be a chore.
And if you recover the sand, it will be contaminated in future use.....
Soot is generally acidic on the Ph scale, so you would want an alkaline cleanser such as ammonia. I've never done it to a pipe myself but, I used to be a disaster restoration technician and have cleaned up after coutless fires and furnace puff backs and have cleaned damn near everything but a muffler. Good luck, let us know how you made out.
If you can't fix it with a, its an electrical problem.
85 ATC 200s--Ratted out and not running at the moment
86 ATC 200x--All stock other than the handle bars
85 ATC 250es Big Red -- Just got new rubbers and she wants to ride!!
04 Suzuki LTZ250 quadsport - It was a decent price and I'm a raging idiot.
i use a torch but bonkers seem to know what he is talking bout so maybe give that a try and let us know
1985 Quad Killer
1985 Mini Raag
1985 Green Gobbin X2!!
1990 Kawasaki 300sx
R.I.P
1985 Quad Killer
1985 Mini Raag
1990 Kawasaki 300sx
R.I.P
that's funny!
________________
https://www.mikesatvfix.com
If it is a steel muffler just take it off and throw it in a fire. Does not need to burn long. Once the oil is heated up enough just take it out of the fire and let it smolder. Aluminum ones I leave on the bike and heat with a propane tourch.
1985 KXT 250 Tecate
1983 KX 250
Proud member of
3wheelerworld.com
3wheeler.org
Planettrike.com
Airfoolers.com
I like the torch idea and raging idiots too![]()
