i need a cdi for my 87 kxt will a kx cdi work thanks scott![]()
84 kxt hulk dune bike
84 kxt 500 coming soon
85 kxt hulk #2 drag bike
86 kxt trail bike for
99 kx 250
Yes as long as the plugs match up with the tecates. I used an 87-89 KX250 CDI on my 87 tecate and works fine.
86-87 Tecate ROCK!
just be careful the kx cdi has amore advanced curve..
You will to have the complete KX system. CDI, Stator, and Flywheel.
1985 KXT250 A.K.A. "Doom"/Multiple Engine Combinations/Jason Hall Inverts/HRE Swing Arm, Cal Fab Swing Arm/Jemco Pipe/Buzz Saw Cylinder, Klemm Research Cyinder/PWK Carb/PVL Ignition/Dura Blue Axle/Mosh Custom Seat
Oh yeah, I guess I should have stated I have the88 KX flywheel and stator kit on mine hehe.
86-87 Tecate ROCK!
So I just put on a new Ricky stator and flywheel on my 86 and I have fire one minute and not the next. So I may need a new CDI or coil. Does this mean that I have to have one of these specifically made for my 86 tecate and I cannot mix and match from a KX?
You cant mix match kx with kxt. One or the other! 1983 to 1986 Kx250 ignitions only will work on the Tecate, but you will need the complete system. If you are using a Ricky stator then it is kxt.
thanks guys that's what i thought my dad and the neighbor got drunk and did some welding on his 87 kxt then calls me and Say's he has no spark so i ask him did you unplug every thing grounds and all he said F%%^^%47^&k what a dumb ass HAAAAAAH LMFAO SO IM GOING OVER TO OHME EVERY THING OUT FOR HIM AND SEE WICH ONE IS BAD IF NOT EVERYTHING ENEY ONE HAVE PARTS ?
THANKS SCOTT
dame caps lol
99 kx 250
