Honestly, it's when guys go 1.5MM or 2MM over stock that the cylinder liner gets very thin and is prone to cracking and can't absorb the heat as well as a thicker liner. But thats .120 or .160 thousandths over and not .020 which is typical and as much as .060 or so.
Allot of 2 strokes back when I was a squirt were pretty much cooked at about .060 - .080 over and you needed a jug. Back them we had no EBAY which made it very expensive to get rolling again.
I put a 2MM oversize and high comp piston in my 87 250SX and along with a cam, exhaust, carb and other changes; It gets up and goes pretty good
The piston was 25$, how could I turn it down
but if I ever need rings, I'll bet I'm done with the "Rocky" piston and 2MM is the absolute end of that cylinder............
BUT, the ES and SX are so limited with there suspension and gearing that can't be changed that a fresh STOCK motor is probably just as fine rather than dumping 600$ into a limited machine.
