Results 1 to 14 of 14
Thread: ATC 70 sputter/bog at WOT
    Santa Barbara, California
    1,161
    So my ATC 70 runs and it runs ok but I noticed it sputters at WOT. Like it just doesn't feel like it has a lot of power, I've tried messing with the carb adjustments and that doesn't really do much. Anything else I could try? The air filter is clean I know that.
    1985 Honda 200x
    Sep 2009
    Washington
    553
    Fuel filter?
    1,161
    Quote Originally Posted by Jeepermc View Post
    Fuel filter?
    Brand new fuel filter
    1985 Honda 200x
    85Tecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Iowa
    442
    Is it modded any? Make sure the main jet isnt clogged. Does it happen when you crack the throttle from an idle? If so, try changing the clip position of the needle. Go either direction and see if it helps. I had a ytm 200 do this and the needle clip position fixed it.
    May 2007
    Coshocton, Ohio
    1,815
    Quote Originally Posted by inv3ctiv3 View Post
    Is it a stock carb? A very small piece of dirt will wreak havoc on one of those.
    Appalachian American Racing
    the home of
    Aug 2009
    Newfoundland, Canada
    915
    governor isnt on is it?
    1,161
    Quote Originally Posted by MudBug View Post
    The governer!? haha I hope not!
    I completely took the carb apart and cleaned everything, all the jets and everything....I can try to do it again.
    1985 Honda 200x
    OHIO
    2,857
    clean carb again and again and 3 more times....... sounds like crud in carb or air filter problem??? Getting to much air somehow??? Some of my 70's are very air sensitive... lol lol soak that carb for a day in evaporust and you will be suprised..... good luck......... hate to see a atc 70 down!!! Breaks CRAZY'S heart........
    UlsterATCFan's Avatar
    UlsterATCFan is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    UK
    363
    LOL you definitely are a CRAZY 70 man
    Aug 2009
    915
    haha so I take it there is no governor on the 70 :P
    Lancaster, PA
    1,738
    Well... there is a throttle limint screw on the back of the thumb throttle on some 70's, I have never seen one that still had it in there,lol but there is a chance, you are suppossed to remove the limit screw and plug the hole with the special short screw to keep out dirt, haven't seen to many with that either, just an open hole. Sounds like you have dirt in the carb or the points need adjusted.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    1,161
    They are brand new points, but if they are out of adjustment it would make it sputter?
    1985 Honda 200x
    Baltimore, MD
    6,088
    I was thinking points myself. Do you have new points and condenser too? Points out of adjustment or old points can cause a sputter.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    1,161
    The points are brand new and I thought they were in spec by maybe not, I'll check them again.
    1985 Honda 200x
