Page 3 of 3 FirstFirst 1 2 3
Results 31 to 42 of 42
Thread: Whats everyones fav. Grip?
  1. #31
    Jun 2006
    holland, ohio
    1,587
    I like the clamp on style but they do wear out fast and are rather thin. I usually buy scott because they are cheap (like me)!
  2. #32
    Jun 2006
    holland, ohio
    1,587
    Quote Originally Posted by 1BFC View Post
    X3.... Can't beat this grip system and it's only $20.00 / pair.
    Here's what they look like installed:
    Good luck with your choice..
    Nice bars
  3. #33
    Lewiston, N.Y.
    1,479
    What about these Pro Grip?? These are what were on her and i liked them alot, the scott grips i had on my sx and i remember them being to tough...these are kinda plush. Not sure why they are wired down though....? Anyone ever use these?
  4. #34
    Daltons200x's Avatar
    Daltons200x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    Levittown, PA
    183
    i just got the pro-taper low-pro pillows on my mx bike and i like them alot so far. and from what i can remember hey werent too pricey
    Rides:
    1983 suzuki alt50
    1985 honda 200x
  5. #35
    Apr 2009
    north tonawanda ,new york
    133
    Scott Hurricane grips is what i run. No problems yet and not a bad price at 9.99 a set from local dealer
  6. #36
    Phoenix, AZ.
    6,719
    I don't know what lock-on grips you guys are using but those Odi "Rogue" grips are not thin or stiff and they don't wear out quick. Personally I think they are the shiznit. I've always had problems with grips twisting and even coming off when riding in triple digit weather no matter what I tried. All the glues just heat up and let go. Obviously that's never a problem with these grips. The Rogue model has just the right amount of rubber to soften vibration too. Thinner than an Oury but thicker than a Scott.
    Maybe you guys were using the Ruffian? It's much thinner. They have a third option now too which looks like it might be a good in between option.
  7. #37
    Aug 2009
    So. IL
    39
    i've never liked grip glue myself. of course if dirt gets under them they'll spin, but i just use a light touch of hairspray. clean the bars and inside of the grips. then it doesn't take much, grip slips on easy, dries in a min and sticks pretty dang good. i might not as hard on mine as some of ya though.
  8. #38
    Sep 2007
    oregon
    2,292
    pro taper pillow top grips, I love this grip on a twist throttle.
  9. #39
    Aug 2004
    Phoenix
    1,229
    If anyone is have trouble with grips spinning, get some Gorilla glue.
    Remove all the warning label and let nature take its course
  10. #40
    I get my grips at the BMX shop, they're Scott grips and the packaging is a simple BAG!! and about 8$, which is perfect for me.
    I don't need a plastic heat sealed box that I need a Sawzall, Circular saw or Oxy/Acetylene to open. They can keep the sticker too
    Lets face it, if you ride and don't just putt putt around, your gonna tear the end cap off of them before you even think about wearing out the compound.
    Hence the reason I run the Scott grip
  11. #41
    TexFest's Avatar
    TexFest is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    U.S.
    339
    scott hurricane atv grips
    TPC 450R
  12. #42
    Oct 2007
    Grosse Tete, LA
    3,441
    OEM all the way
