Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: 85' 250R Rebuild Frame Base Coated!
    Apr 2009
    alvordton oh
    70
    85-86 axles will interchange the only difference is the taper on the 86 is thicker so you need to use the washer that slides over the snap ring is the same year.
    NewfieBish's Avatar
    NewfieBish is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2008
    Cupids, Newfoundland
    267
    So what do you guys do with your frames while you paint them? How do you hang them so to say haha, can't really think of the way to do it
    85' ATC250R
    Sep 2009
    Suring Wisconsin
    967
    I like them hung level, the way it will sit when assembeled. That way the parts that are seen the most will be the easeist to paint. Also about cheast height that way you are in a good working position. I like to use small wire, you can spray right through it with out getting build up.
    Oct 2006
    2,504
    NewfieBish's Avatar
    Sep 2008
    267
    sweet! that's an awesome idea. just finished sandblasting tonight, should be ready to prime and paint now. post some pics when i get a coat on it!
    85' ATC250R
    Aug 2009
    Newfoundland, Canada
    915
    sounds like its going to be a good build!
    Escondido,CA.
    111
    Ive heard of some old timers using barbecue paint? I have never used it.
    NewfieBish's Avatar
    Sep 2008
    267
    Alright so the frame has been primed and painted with a good base coat, now I have to prime and paint the swingarm, and all the peripherals (hubs, motor mounts, triples, etc.) then once it's all been primed and base coated, the clear lacquer comes in! It takes way longer to sandblast and wire wheel a frame than I thought, but I'm really glad I done it because now the frame looks way smoother than if I had to have left some paint on it! Here's the near finished product without clearcoat!
    Attached Thumbnails Attached Thumbnails Frame Painted 003.JPG   Frame Painted 004.JPG
    85' ATC250R
    Apr 2010
    clarenville
    36
    will you sell er
    Jordan patey
    85 honda 250sx with 300 honda motor
    81 honda 250r
    83 honda atc 110
    84 honda atc 70 with 125 lifan motor
