Hi,I have a tri z 250 85 year and i was just thinking if any other engine would fit in the bike,Or if the power band can be taken off the 250 engine that is in it now,Thank you
oh gawd...... things are fixin to get ugly....
unfortunately - the Tri-Z power band will only fit in the Tri-Z engine.
Are your Power bands old? Maybe they just need replaced. Are they dry rotted?
Honestly I always try to run two powerbands...seems to help tote my big butt around.
Then when you stop you can pull one off and flick it at someone.
^ It's always you Goat!
You always go back on things you said before, I quote Goat: "If you put a 4 stroke powerband in place of a 2 stroke, you get smooth clean power and not that arm jerking 2 stroke power"
Thats what I did with my 250R and I'm so glad I did. It's been easier to ride and doesn't foul plugs ever anymore![]()
I'm sorry steve, I just have the worst memory sometimes, and don't remember what I've said.
You're right, a 4 stroke powerband in place of a 2stroke will help get a smoother power.
I personally like the 6 stroke engine design which alternates a nitrometh and gasoline.
Hi Guys,Thank you for the replys,I think i may need your help a little more...so tell me more about the 4 stroke power bands...what bike are they off where can i get my hands on one...it sounds just what im looking for ..when this bike takes off on me it nearly pulls my arms out of my sockets....would it be ok if i could email you to fnd out more please?
sure, steve won't mind a few emails, he's a people person.
EDIT:
I AM NOT STEVE!
STEVE IS DIRTCRASHER!
talk about your all time backfires....
We haven't had a good epic 30 page saga thread on here in a while....it truly might be about that time.
Why did this have to happen in the morning!
i run a 4stroke powerband in place of a 2stroke & it works amazing...you should try it, also try a powerband adjuster so you can limit the powerband from mild to wild.
So can you help me with changing from a 2stroke power to the 4stroke power band ?
Thank you
What bike did you get the 4stroke power band off ?
a common donor is the raptor 660...but don't tell anyone I told you that
