Thought I would share some pic of another one of my 200x s . This one is pretty much all curtis sparks old skool stuff . Sparks ported head , cam , Valve springs , header and lightened crank . The carb set up is an aftermarket alum intake with 28mm mikuni flat slide . The +2 swingarm is kinda rare made by CT racing and im also using an aftermarket shock spring I believe made by works . The tank is an old IMS short track plastic tank . rear axle is a +6 durablue . Front forks are 1983 atc250r which I believe gives it 3 more inches of travel plus it makes the trike sit better with the longer swinger .
