Thread: headlight problem
    Aug 2003
    3
    headlight problem
    i have a 83 atc 200 and the headlight is very dim its a new bulb 45/45 watt and the wires are all great shape and the tail light is bright i checked all the conections and cleaned them thanks anything would be thankful
    Eastern Long Island
    1,688
    Check the handlebar switch. It may need cleaning oe replacing.
    Lots O Trikes!!!!!
    Aug 2003
    3
    thanks but i tried that
    Dave is offline New to the board Arm chair racerNew to the board
    Jul 2003
    37
    Try disconnecting your tail light and see if your headlight gets bright.
    I have this problem on my 185s... if the tail light is on the headlight gets very dim.. I tried cleaning everything and it still does it with a new tail light...
    If this is your problem, and you figure it out .. please let me know the solution ... for now I go without a tail light.
    Aug 2003
    3
    that worked thanks alot it works great maybe it is a weak lighting coil ?if it has one thanks again dave
