Results 1 to 15 of 16
Thread: 185s no spark?
    kyle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2003
    291
    185s no spark?
    My buddy has a 1982 Honda 185s and the other day we were riding and all of the sudden it quit running then it would not start again. We started checking wires with a multi meter and everything appears to be good. We checked and we are getting no spark. Any suggestions?????
    1986 Honda 250SX
    Jun 2002
    Mississippi
    2,552
    pull the little cover that says "CDI" off and try to start it. does it turn? if not that may be your problem.
    chris
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Apr 2003
    291
    Yes, i already pulled the CDI cover off, seems to be working fine.
    1986 Honda 250SX
    Dave is offline New to the board Arm chair racerNew to the board
    Jul 2003
    37
    I just had this problem with a 81 185s .. not saying yours is the same .. but could be. My machine did not die while running, it died somehow while parked a couple days.
    Under the CDI cover is the spark advancer. It looks like a rotor with a couple points... be sure to clean it up where it has constant contact and the tiny springs are in tact .. if you sand it be careful not to leave any sand behind to obstruct contacts. If this doesnt work, try to *borrow* one of these assemblies from a running machine and try it in yours to see if it starts... I just got through this problem .. it took several days of tinkering to figure it out.
    You could also have a problem with the kill switch.. As another person suggested to me ... disconnect it under the headlight and try turning it over.
    In the end I could see no visual spark .. my machine didnt start until I towed it and it popped right off.
    Good Luck
    Jun 2003
    Lake George, New York
    1,732
    Try the coil
    '86X is offline First Time Rider Arm chair racerNew to the board
    Jul 2003
    136
    185s no spark
    Just keep senselessly throwing part after part at until it starts
    '86 ATC 350 X FOR SALE-- GONE!
    '86 ATC 200 X PARTING OUT
    '95 Banshee--The most feared ATV ever built
    '95 KX 125
    '98 Polaris 700 XCR
    '65 Mustang!!
    Jun 2003
    1,732
    Try the coil first before you put that much money in it. LOL.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Things to check:
    Spark plug ( I have seen new plugs that were junk )
    Check the spark plug boot for cracks or bad connections.
    Check the exciter coil: It's the black with red striped wire from the stator. It needs to be 215-240 ohms. If not replace the exciter coil.
    Unplug the black with white striped wire from the kill switch and check for spark. If you get spark it's the switch.
    Check all connections and wires to be sure they are getting good contact.
    Check the CDI pick up coil ( on the end of the cam ). Check it for correct timing / spacing.
    Check the Advancer unit on the end of the cam to see if it turns without the motor. Also check to see if the springs and little tabs are intact.
    Check the CDI module mounted to the frame.
    I hope one of the above helps you out.
    Howdy
    Jul 2003
    37
    Howdy ...
    I know what the book says with the *215-240* on the coil BUT we have 3 of these machines here that all currently read at 196-198 and are running fine. I replaced one recently when I thought I had a coil prob .. the new one read 197.
    I'm not trying to step on anyones toes, or imply the info is bad, Just trying to save someone a few bucks.
    On occasion, the books can throw us off.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by Dave
    Howdy ...
    Yea, some will run with a lower ohm reading. How ever to get the best spark and running ability 215-240 ohms is where it should be. I only mentioned this because he isn't getting spark. When I'm working on a machine at the shop I do not check the exciter coil unless there is a problem with the spark ( no spark, weak spark, or spark plug fouling ). Once in a great while I will replace a exciter coil and it don't help. I just simply put the original back in.
    Just like you I do not like to spend money unless it is needed. It don't grow on trees here either. lol
    Howdy
    Jun 2003
    1,732
    Quote Originally Posted by Howdy
    Things to check:
    Howdy
    Sounds like you called Mr.ATC
    Apr 2003
    291
    I just want to thank EVERYONE for helping me out here. i have not had the time to mess with the trike, but i think today i am gonna go get the thing running.
    1986 Honda 250SX
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by airmancam
    I have been working on ATV's for well over 13 years. And I have been giving such advice here years before MRATC even came to the site. I joined in 1999.
    He does things his way, and I do things my way. We might not always agree with the way each other does things. But the bottom line is either way they get repaired. It's like going on a drive. You might not take the same path but the destination is the same. hehe
    No offence to anyone. Just wanted to clarify things.
    Howdy
    Jun 2003
    1,732
    I know a lot of people have info and its cool to help out.
    Apr 2003
    291
    Well, today i got the 185 running. We pushed started it and she popped right off. But it would not start by pull start, so i put the old plug in it and now it starts just fine, not too sure what the problem was but it seems to be running alright now. lol
    1986 Honda 250SX
