I have a problem with my youngest being too small to handle most atv's.. I have an ATC 70 for him but he still can't keep it stable with weighing less then 30 lbs.. He's 5 so he is very small.
So I have been thinking about this for a while. Here is my idea for him.
I am planning on building him a mini 2 person UTV.. something small but able to be jumped as well as a small bed on the back. I am talking pretty small. About 2ft longer then a full size atv.
This is what I am thinking:
-Using front suspension from a 300ex as well as the front section of the frame.
Frame will be made from 1" square tubing .. 1/8" thick for the main points, thin wall for the rest of the floor board supports.
-2 child jr dragster seats
-rear swing arm from a ATV.. should hold the weight since it really will not be jumped too high. But may just be a custom engine cradle with the suspension attached. Don't have the money for independant rear suspension like I want.
-Plan on using 18x9.5x8 rear tires on 10" wheels.
-engine I am thinking a Lifan engine 125cc. Not sure if it can pull around the weight of it or not.
-small ATV winch mounted on the front- to pull his brother when it runs his atv off the trail.
-full set of offroad lights
Have some questions:
SHould I just go with a larger engine to start?
Not sure what size tubing to use for the roll bar
Any opinions would be great. This weekend looks rainy so I think me and my boys will start it this weekend. By hacking apart the 300ex donor frame. Should be fun to see a 5 and 8 yr old use a sawzall.
