Other than mount mods and fabrication, would there be any showstopper reasons why this couldn't be done? The drivetrain is on the correct side so it seems possible.
It's a celebration bitches!!!
Your talking about the motor I assume? What year and size YZ motor were you thinking about using? From what I have heard the 83-87 YZ 250 is a direct bolt in. The YZ suposedly has more radical ports, a little higher compression, and of course the power valve system. In my opinion the power valve system dosnt add more power, just gives you a little better control of where the power comes from, and when you want it to hit. It takes that "light switch" feeling away when you crack the throttle, and you know where it is. The kicker can be set up to kick forward, just like the tri z motor, you just have to swap some internals between the two. Good luck, and let us know a little more info!
81, 85 Yamaha Tri Moto 125
83 Yamaha Tri Moto 200 x2
85 Yamaha Tri Z 250
84 Kawasaki Tecate 250
84 Honda ATC 70
85 Honda ATC 350X
84 Honda ATC 250R
(2) 84 Honda ATC 200x
82, 83 Honda ATC 185s
81 ATC 200
Lots of other parts and bikes
If you are up for some cutting and welding try the yz400F or the 426 they are reliable and pull like crazy through the whole RPM range.
I thought about doing this a few years ago.
I was looking at doing a 93-98 YZ motor.
Lots of parts for them.
Just never got around to it.
Looking at those years of engines, they looked likt they were close as far as dropping right in.
I am sure there would be issues though..LOL
Pipe fitting,at the newer jug, carb clearence issues,and intake set-ups, not to mention,adding a fuel pump port on the newer jug, or going with a top mount tank.
Also, the newer engine would require a cut fender to kick it backwards.
Proudly NOT a member of
"Team on the Teat"
what about banshee low pro fenders for the kicker problem?
MAke sure you install new power bands if you put a YZ motor in.Dont want them failing when you need them!!!![]()
Yes Mike I am glad you mentioned this it was in another thread but I will mention it again .... DON'T use the power band from the yz250 put the power bands out of a four stroke in the 250 motor it will pull right of of the bottom end that way it is a great mod i can't see why more ppl don't do this![]()
Ohhhhhh here we go again..............![]()
85 Yamaha Tri Z 250
84 Honda ATC 70
85 Honda ATC 350X
84 Honda ATC 250R
81 ATC 200
1985 Quad Killer
1985 Mini Raag
1985 Green Gobbin X2!!
1990 Kawasaki 300sx
R.I.P
I love these. Blue ones work good too. make sure you get the tapered end muffler bearings too.
I broke the powerband on my tri-z recently. Lucky I had a spare one for my 250R. And it will drop right into the Z.
I just wanted to comment on the power valves. They were never designed to increase the top end output. Rather they were just a devise to add low end without sacrificing top end. Early PV's consisted largely of a bufferfly, flap or some other obstruction in the exhaust port to restrict the flow of exhaust at low lower rpm.
I'm not very familiar with the YZ design, but looking at pics from 85 it appears to be a similar "basic" drum that limits the exhaust flow. At some point through 1998 it looks like it evolved to actually change the compression ratio and port timing. In 1999 it definitely changed to the Honda design (like most others use) which essentially gives you two engines in one. Below 6000 rpm is about 11:1 compression, above 6000 rpm is around 9:1 compression. The torque increase is the real advantage with PV's.
(if you click this stuff, you will see pictures of this stuff)
2001 Indian Scout
2011 KTM 250SX
1986 ATC250R
1989 Thunderbird SuperCoupe
2006 F150 Crew
