is there any difference from the 1st gen 200x crank and say other honda atc 200 model cranks,besides the parts numbers.reason asking is bc im wanting to stroke(powroll) a 200x and i already have a 200m crank out the engine.
Signature pic removed,becuase of no helmet.
An auto 200 crank is different than a motor with a manual clutch crank and also the xr200 cranks use a different rod that is thicker and doesnt use the shims at the bottom bearing .
after i took out the 200x crank i seen what you were talking about and its a big diff between the two.
i have a 85 200x crank that needs a new rod you can have if you wanna pay to ship it.
Rides
85 ATC350X
85 ATC200X
