Thread: 1980 Honda 110
    1985BigRed250ES's Avatar
    1985BigRed250ES is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Rison, Arkansas, United States
    397
    1980 Honda 110
    I have been restoring a '80 110 ATC. In the process of restoring it, I had to swap the heads out due to the old one being stripped. the head that I purchased had the CDI setup in it. my atc has the points setup. I had that swapped out at an atv shop. while it was there I had the timing chain changed. I got it mostly back together now except for the muffler and seat. The first spark plug was new and it lasted two weeks. I wasnt fouled, just would no longer fire. I purchased another new NGK D8HA plug from oreillys and it has lasted until two weeks ago(last time it ran). It was kinda sooted but not fouled. I did clean the plug and it will not fire. I put in a "test" plug and it ran great. the plug that came out of the ATC was checked with a meter and it shows to have continuity(sp?) through it. It refuses to fire on the plug. it will only run on the test plug which is a plug I borrowed from grandfathers bigred, take into account that I didnt screw the "test" plug all the way in. My question is: What could be causing the ATC to go through spark plugs? any help will be appreciated. I do have a manual.
    1985 Honda BigRed 250ES
    runs good all original
    Restoration in progress:
    1980 Honda ATC 110
    1985 Honda ATC 250SX
    1982 Honda 200ES BigRed
    1984 Honda 200S
    1984 Honda 200S parts bike
    1985 Honda ATC 110
    1983 Honda ATC 110 parts bike, runs but smokes
    Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
    397
    oh BTW I am also running it without the muffler, can that have an effect on the plugs?
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    Aug 2009
    Newfoundland, Canada
    915
    without the whole exhaust or without the muffler itself?
    Baltimore, MD
    6,088
    I don't know if the muffler would expect the spark plug, but it isn't healthy for your valves. At least find some kind of universal muffler for it and give it a little back pressure. Also a straight through pipe is more than likely hurting your performance, your exhaust needs a measure of backpressure.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    85Tecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Iowa
    442
    I ran a straight pipe on a YTM200. Ran the piss out of it but did seize the engine up 3 times. I think it was due to a 40 over bore and lack of oil to the top end. The cam bearings are what seized. Anyways, it ran perfectly fine other than that. Not sure exactly what caused it.
    397
    I will try to get the muffler repaired soon so that I can put it back on the ATC. I am running it with just a pipe and no muffler. Could it be firing too hot, causing the plug to burn out? is that even possible?
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
