Results 1 to 15 of 18
Thread: whats better time sert or helicoil
    Escanabajosh's Avatar
    Escanabajosh is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    U.P. (upper michigan)
    352
    i'm planning on fixing the 1/2" threaded tapper for a oil plug that came on my 250sx.....it worked for a little while but now it leaks like crazy. i picked up the new drain plug and washer (around $2.50, i figure sweet ain't gunna cost much to fix!)
    so i started to price the time sert and they want $100 for the kit! helicoil is like $50. i read the "how-to" threads on here about the two but since i'm laid off right now so i don't have much money let alone $100 for a tool i won't use much.
    any ideas or tips? i put a add on CL for a used one....but i got $50 and i wanted to do it today.
    Back in Happy Valley
    833
    keen-serts are pretty affordable, and they use std threads, i dont know how well it work for a drain plug but if you ground it down so it didn't stick up and plug sat flush on the case i think it would be fine. Then you can just use a std tap.
    Try calling a local engine builder or machine shop. Worst case you can switch it to SAE and use something readily available for plumbing if you're in a bind...
    86 350X
    85 350X daily rider
    LC 250R
    85 T3
    86 T3 roller
    85 250sx beater
    Dec 2007
    Quebec,Canada
    1,014
    If you have a 1/2 thread now,you can bought a M14x1.25or1.5 tap and do new thread with a new plug,or go to M16x1.25 or 1.5.
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Apr 2009
    Franklin NY
    41
    that is way to much money for what your tring to do
    try a good local truck garage they normally have what you would need.
    86 350x
    07 450ER
    Every time you need a thread fixed, get a kit (if you can afford one). In time you have 6 kits that fit 90% of all threads!!
    Nope, not cheap but neither is the part with the junk thread.
    I love helicoils, never had one fail (DC knocks on wood) and many times, I buy the tap, coils and already have the drill in my index and wind in the helicoil with a small flat blade screwdriver. So it costs me 15$ for the tap give or take and the coils are either under a 1$ or a bit more. I buy packs of 10 of the coils. Or you can buy 5 kits at 45-65$ a kit...........
    So I can pay 100$ for all 5 normally sized taps and an assortment of helicoils, if I don't need a pretty box/chart and drill bit.
    ANY fully walled insert is gonna be optimum over a coil, but the Helicoils work just fine IMHO.........
    Last edited by Dirtcrasher; 10-19-2009 at 08:52 PM. Reason: I'm stupid, I added crap!!!!!!!
    Apr 2008
    Kalamazoo, Michigan
    814
    If you go to advance auto, they have kits for $20-$30. You can buy the tap and everything for your specific size.
    Leave feedback for me here : [Please Don't start another thread again!]
    http://www.3wheelerworld.com/showthr...for-MagicJames
    Current :
    86 250SX
    86 350X
    86 250R Project
    Owned and Sold
    85 250R
    2 ATC70's 84 and 79
    PA
    3,515
    helicoils are great, just fixed my drain plug with one.
    like DC said, i never had one fail.
    WWW.HREATV.COM
    Oregon
    2,471
    Time Sert -
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    just re-tap to the next size up bolt.......
    Dahlonega,GA. (Formerly Flint,MI.)
    787
    Time Serts
    "You should never smoke in pajamas..
    You might start a fire and burn your face..
    Maybe you should return to Manaugua..
    You could go un-noticed in such a place"
    FZ
    Ass,gas or grass....nobody rides for free!
    Ride free,Brotha. See you in Heaven.
    Oct 2009
    352
    well the guy at the parts store saved me a few bucks. showed me somthing called a piggy back drain plug. it's a bolt a little bigger then 1/2" and it self taps into the hole. the middle of that bolt is drilled out and has a smaller bolt in it that you remove to drain the oil. cost $10 even for the bolt and a tube of loctite.
    i'm giving it a try. right next to the oil drain hole there is a little raised part, can i grind that down and not affect anything? figure i better ask befor i do! the piggyback plug is bigger and will hit that raised part so it won't seal up tight. i have a angle grinder and was going to make it as close to level with the case.....
    na
    5,702
    Just get the helicoil kit and do it right.
    That 10$ Hokey part could ruin a set of 400$ cases.
    Proudly NOT a member of
    "Team on the Teat"
    Oct 2009
    352
    i wanted to do the helicoil but i just didn't have the extra cash. i ended up using a small cold chisle and removed the little lip and then sanded down the little that was left. i ran the bolt thru,then took it out and put some lock tite on. seams to have worked perfect. snugged up real good. i'm letting the loctite sit for a few hours till i add oil. if it don't leak, it will have been worth it i think.
    Sep 2007
    California, USA about 50 miles north of sacremento
    976
    I use helicoil but I am curious what your talking about? Got alink or pic or name etc? This would be a good thing to keep in my toolbox when out on the road or riding. A quick fix to get ya home..
    Oct 2009
    352
    this should bring ya right to the web site. i bought it at carquest for a little over $5. the washer they gave with the plug is small so the guy behind the counter gave me a little bigger plastic washer. i havent put the oil in yet but it seams like it will work good. i whouldn't ever have to take out the big one so it's kinda like a external helicoil.....i guess. the guy at fastanal said helicoils might back out taking the plug out, don't have to worry about that with this thing, just put a wrench on the big one if the small one is on to tight so it don't back the whole thing out.
    https://www.dormanproducts.com/cgi-b...tegory_list=:0
