Results 1 to 15 of 24
Thread: What octane gas do you run in your 250r?
    ATC350X 85 is offline At The Back Of The Pack Arm chair racerFirst time rider
    I have an 86 250r that is bored .25mm over (.010 over) with a factory honda piston, an old school answer silencer and uni filter. I run Sunoco 94 octane at 40:1 with bel ray mc:1
    Justin
    04 Trx 450r
    85 Atc 350x
    86 Trx 200sx
    00 Xr 400R
    85 Atc 70
    98 Toyota Tacoma 4x4 xtra cab
    99 400ex, 97 xr400, 85 Atc 110, 86 Atc 200x, 85 Atc 350X, 87 Trx 250X, 86 Atc 250R (mint), 78 Atc 90 all sold
    Mar 2003
    West Monroe, LA
    847
    I have an 86 250R W/LRD 295 big bore kit W/ MX port job, shaved head, 39mm Air striker carb. Boyesen Rad Valve W/carbonfiber reeds, Dial-A-jet, No air box K&N W/ Outerwear and FMF Fatty Pipe W/Power Core silencer and I run 112 VP at 32 to 1 W/ Castor 927 oil.
    I rum VP C12 mixed with maxima 927 at 32:1
    the motor mods include...
    .080 over piston
    lighter crank
    higher compression
    ported
    CR gaskets
    balanced/blueprinted
    Rad valve
    Paul Turner pipe/silencer or phase 5 pipe and comp 2 silencer
    39mm pwk carb
    CR 250 ignition (no lights, lighter flywheel)
    Nov 2001
    B.C.
    933
    Stock 82 250R with 87 octane and Torco mix. Runs just fine!
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Feb 2003
    southwestern NY
    641
    mine is a 265 with full porting and after market head.I run 115 octane
    turbo blue with klotz r 50 at 32:1
    atc86r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    bangahore, mi
    306
    114
    2strokepwer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2003
    Mississippi
    359
    110 blue thunder
    2 strokes feel the power
    Jun 2002
    Mississippi
    2,552
    93 at 40:1 PJ1 synth. and it runs great!
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    MR ATC, for what my 250r has done to it, is what Im running good in your opinion? It runs strong, i was running 102 and 94 mixed 50/50 and it ran just about the same but was killing my $$ so i went back to 94
    Justin
    04 Trx 450r
    85 Atc 350x
    86 Trx 200sx
    00 Xr 400R
    85 Atc 70
    Bill X_R is offline Bill "The Finger" XR oo|oo Arm chair racerJust too addicted
    Feb 2003
    Cincinnati, OH
    672
    Not one person posted what there comp ratio was...Isn’t octane grade determined from this?, and anything above that is a waste of money? I guess you could argue that it may run cooler therefore more efficient. I think that’s minimal at best.
    Hmmm
    86' 250 R
    02' DS 650
    03' Cannibal
    03' Haspin Vet
    04' Haspin Vet
    05' Haspin Vet
    Jun 2002
    Mississippi
    2,552
    Quote Originally Posted by Bill X_R
    Hmmm
    compression ratio on a ywo strok is way more complicated then on a 4 stroke. the static compression my be low but with the back pressure on the pipe it may be 12:1. it gets tricky.
    83 ATC70
    85 ATC70
    86 500r
    Lots of parts
    My 500R
    Quote Originally Posted by ATC350X 85
    for your motor 94 octane is more then sufficant.
    you can run CR 250R head and base gaskets to bump up the compression a little bit and still get away with 94 octane.
    you wont have to go higher on octane untill you have your head shaved or the dome reshaped.
    also if you used TRX 250R gaskets you lowered your compression
    Feb 2003
    southwestern NY
    641
    Not sure of ratio,But it has over 215psi of compression.I was told to run between 110 and 120 octane.
    I run my 250R with 92 octane and Motul 600 oil mix 1:32 and it run well and strong. Still got the original 1985 piston on.
    No mather if it's an Atc 90, Bigred, Tri-moto, 200X, 250R, 250SX, 350X, you always get fun cause a Trike is a Trike!!
    My R is 21 years old i havnt had to bore it or anything the only thing i have done to it is rebuilded the carb
