Thread: 350x Cam journal help
    Oct 2009
    tennessee
    Have just got a 86 350x given to me in a box. Top end of the motor is all apart. My question is the cam journals. How bad is too bad? There are some pretty good gouges on both the head and the rocker box. And are there supposed to be any sort of bushing or bearing? or is it just steel cam on aluminum? Any help would be great. And can get pics if nessasarry.
    Quote Originally Posted by trail boss View Post
    I'm pretty sure the cam just rides on the aluminum. I think they could've designed that a bit better.
    85Tecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Iowa
    442
    If you wanted to you could probably have the cam ends turned down and get some special made bearings for it. It would save the head and would probably last 30 more years with those bearings.
    Quote Originally Posted by 85Tecate View Post
    It's easier said than done. I used to work for a machinist who experimented with that exact situation.
    Jun 2003
    englishtown NJ
    2,676
    xr's only does this to xr motors, they have the same problems. Did anybody try and see if they can help the 350x situation?
