Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: My best deal yet...
    Nov 2008
    Coon Rapids, MN
    956
    So cox did you pick up your trikes yet?
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    cox's Avatar
    cox is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2009
    Edmonton alberta canada
    552
    indeed i did, i picked them up on friday night. Saturday i was couch ridden, my wisdom tooth was acting up very badly. My wisdom teeth are fused to my jawbone, requires a pretty painful extraction. This week hopefully. anyways, sunday i got them unloaded and chcked them out a bit. when i picked them up the owner coldnt get either running. He was persistant that they ran and literally spent like 2 hours trying to prove his fact. in the end i said screw it, and loaded them up. It took me about 5 minutes and a fresh plug to get the one without the s running. Ran like crap, but it still ran. changed the oil, filled it with fresh gas 50:1, and left the carb and oil injection alone for now. Oh, and i cut off the plugged inline fuel filter. Took it for a spin, in about 5 minutes was running really good. a 10 minute ride turned into 2 hours. It ran better after i got that old gas out of its system. She smoked alot, i guess the oil injection was still working, and i double timed the 2stroke oil, lol. I took that homemade rack off, and put a real grab bar on it. The other one with the s has a pullstart that about 2 feet long!!! It has great compression, and should run without much effort. I didnt even try getting that one running yet. The pullstart was pissin me off and my face hurt so i went home. Im going out there today for a few hours ill take my camera and get some better pics of these things. The one runs great and the suspension on both work great so for 300 bones, i got a running 175 and at minimum, a parts bike and a donor for the 125.......
    I wont be keeping those s either....... lol
    R.I.P. Yamahondaman
    Still practicing my NoobiX cube, take it easy on me...
    1982 Yamaha YT175J ( Not much left but the 's)
    1982 Yamaha YT175J
    1983 Yamaha YT125K + 175J =
    1984 ATC 200ES BR - running again - Camchain noise holding me back....
    1984 ATC70 -SOLD-
    cox's Avatar
    Aug 2009
    552
    I got the other one running with little effort. Eliminated the oil injection on both today as well. The first one i got running, runs really good. The other runs ok, havent cleaned the carbs on either yet tho. And the shift linkage is all warn on the one i got running today as well, you literally have to lift your foot to shift up, lol. seems pretty easy and cheapish to fix tho, which is nice.
    R.I.P. Yamahondaman
    1982 Yamaha YT175J
    1984 ATC70 -SOLD-
    drhatc200's Avatar
    drhatc200 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2007
    northcarolina,wilkes county
    214
    this was the first trike i ever rode one of my buddys had one when i was in like 5th or 6th grade maybe so id say it was about new then on my 2nd one of my own now had a 85200x now got a 84 250r got the r for 450
    cox's Avatar
    Aug 2009
    552
    so on my yt125 there is only one fuel line directly to the carb. on these yt175's there is a box after the petcock, which bleeds into two lines, one goes to the carb, and one goes directly into the intake after the carb? Me no understand, someone explain? old yellow?
    R.I.P. Yamahondaman
    1982 Yamaha YT175J
    1984 ATC70 -SOLD-
    Is that an oil injection line??
    Just throwing it out there
    No worries, the Yami guys will be in soon and MonroeMike will hook probably have a manual for ya
    Do a search, you may find something..........
    cox's Avatar
    Aug 2009
    552
    bump for an answer. I looked in my manual mike sent me and couldnt find an answer. ill have to look again i guess, lol.
    R.I.P. Yamahondaman
    1982 Yamaha YT175J
    1984 ATC70 -SOLD-
    cox's Avatar
    Aug 2009
    552
    hmmm, i looked a couple times since then either im blind or stupid. Will someone show me the way? lol
    R.I.P. Yamahondaman
    1982 Yamaha YT175J
    1984 ATC70 -SOLD-
    Nov 2008
    Coon Rapids, MN
    956
    I think the box your talking about is fuel pump, there is two lines the first one goes into the fuel pump from the fuel petcock and the second line runs out from the fuel pump to the carburator, the third line runs from the intake to the pump it is the vacum line that operates the pump.
    Does the pump look like this.
    http://www.denniskirk.com/jsp/produc...fCatId=&mmyId=
    My feedback.
    My album
    cox's Avatar
    Aug 2009
    552
    ahhhhh, i gotcha. old yellow FTW.... that doesnt make me any less retarded for not figuring that out for myself. mind you i dont have my trikes here at my house to work on .
    R.I.P. Yamahondaman
    1982 Yamaha YT175J
    1984 ATC70 -SOLD-
