Results 1 to 9 of 9
Thread: Subaru o2 sensor help
    So I've got a 96 Subaru Impreza with a 1.8. I need to replace my o2 sensors but I have come across a little issue. Some places I look have one part# for both the before and after cat sensors. Other places have two different part #'s for the two different applications. Now here's where I get the red flag- The "good" companies like Bosch, Walker, and Nippon Denso all list two different part #'s. The "crappy" companies, like the things you see on Ebay, all list just one part # for front and rear sensors. I'm not talking about universal sensors either. I don't like those and would prefer not to run them. I typically will spend more money to do the job right, I'm not one to cheap out on parts. I just would like to know how some companies can sell a multiple application sensor and some can't.
    Oct 2009
    lindenwold new jersey
    890
    I've got a 94 and an 05 and I'm allways at a loss when it comes to their motors. Subaru loves me everytime I drive in the lot. I've allways just went with Subaru parts or what ever the part they can get. My 94 Impreza Outback Sport is the best car/tow veheicle I've ever had. Sorry I don't know the anwser but I just let the mech run with it
    That's OK, thanks for the response.
    It's funny that you say that about towing with these cars. I've had some serious weight on my trailer and I cannot believe how well this car tows. It's just a tiny little thing, but it tows like a fricken truck!
    Jun 2009
    Kentucky, USA
    59
    According to alldatapro.com a 1996 AWD 1.8L SOHC uses the same sensor front and rear and it only has 1 part number listed. OE p/n is 22690AA220.
    Why do you need to replace the sensors? Do you have a check engine light with this code or does it have an O2 light?
    The reason I ask is my 89 Amigo had a O2 light that came on at 80K miles and the only fix (from the service manual) was to move the bulb to a different socket in the cluster, and then it would come on in another 80K and then you remove the bulb and leave it out.
    Current
    87 250ES & 87 250SX
    Previously
    87 230 Quad Runner, 86 RM125 (RIP), 84 200X
    Cars
    84 C-10 2wd w/ fuel & N2O injected 406
    87 Camaro-> Work in progress for the Silver State Classic
    My check engine light is on, and the codes are for o2 sensors. That's funny that alldata says that because like I said, the good brands list 2 different ones.
    litebulblsc's Avatar
    litebulblsc is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    LaSalle, MI
    313
    Just because you have an o2 dtc, doesn't mean the o2 sensor is bad. If it was the one before the cat, it could have sensed a lean or rich condition caused by something else. If it were the one after the cat, the cat could be bad.
    And a red 2000 silverado
    Ashland City, TN
    2,576
    In that case fabio....I'd probably just go to the dealer for the parts. It'll probably cost more but saves headaches in the long run.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Apr 2008
    somerset ma
    1,822
    So what you are saying John, your Subaru has got the FLUbaru again?
    Or is it the Swine FLUbaru this time?
    Alright, Roy, Alright. Hahaha. I just got two Nippon Denso sensors, both the same part # and put em in. I'monna throw it on the computer Monday and see if the codes are gone.
