Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: Tachyon xc helmet cam
    Jan 2005
    RI
    2,530
    damnit...any way for me to get you a video to edit? once i get the hd, whats the easiest way to send it to you? I can F around with movie maker or go get premier pro, but i never have time to up pics let alone edit .
    another options is just to give the memory card to jeff after the ride...im actually gonna go buy one right now
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Phoenix, AZ.
    6,719
    I don't know if I even can edit the HD stuff. My old PC has a hard time with even viewing HD video.
    The standard def stuff I don't have any problem with.
    Jan 2005
    RI
    2,530
    well i just bought it...315 shipped to my door....
    gonna start dl'ing premier pro now
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    May 2007
    oroville ,,ca
    72
    It's Sand Mountain Nevada which is 235 miles from home..we make about 5 or 6 trips a year and go riding there... It's a blast! I have Adobe Premeire elements 7 and it taxes my Pc real bad.. What I found recently was if I immediately convert the files to WMV files and reduce their size then do the editting it was much easier on my pc..what ever camera you choose have fun! And let's see them videos!
    greythorn3's Avatar
    greythorn3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2007
    ALASKA
    302
    Quote Originally Posted by pinstriper View Post
    r you sending me a camera to try out?
    1985 big red 250es working good. 1983 200e waiting for new crank and rod. 200x project looking needing everything.
    May 2007
    oroville ,,ca
    72
    Sure ,just paypal me $200
    Feb 2009
    michigan
    2,387
    Tachyon Inc. Makers of tachyon xc helmet cams recently had a video contest. Un be known to me they entered two of my riding videos taken with their camera in the running. As luck would have it I was selected a winner along with a few others. We won $600 worth of helmet cameras and software to make 2d and 3d videos. The new 2010 model has a 90* field of view which is about a perfect match to what the eye sees. I mounted it to my bumper this weekend we we went to the dunes.. Check out the quality of the video taken from a camera that was mounted to the front bumper... Unlike the GoPro which is really distorted video I think they nailed it... Hope ya like it. Never mind the comments of choice of music ... It's all about fun http://www.youtube.com/watch?v=VnYVjHUlINE
    most people have 180 deg. field of vision not 90 deg.cool camera though.you cant beat a gopro though.best camera for the money
    1985 ATC 250R
    . Team Red Trike
    May 2007
    oroville ,,ca
    72
    I'm half tempted to put this to rest... I may end up ordering a GoPro hd and mount them side by side for the next trip.. then make a split screen video or just two videos ansd show that the XC gives a better "normal" picture.. My eyes might be 180* but I ain't got got no fisheye lens in my cornea.. worst case is I'd lose $50 after peddling it on Ebay..
    Phoenix, AZ.
    6,719
    You just don't like the wide angle lens effect. Nothing wrong with that but it doesn't make one better or worse than the other. A lot of people prefer the wider view. My first helmet cam had a 90 degree view and I didn't like it. When mounted on the helmet you can't see nearly as much. I like to be able to see the handlebars and everything.
    Phoenix, AZ.
    6,719
    Here, I thought of a way to illustrate the difference and why some people like wide angle and some hate it.
    I used an old video game. First screen shot is set to a 90 degree field of view (fov). It looks perfectly natural like a Tachyon.
    This screen shot is set to a wide angle fov. Not quite 170 degrees though because the textures in the game wig out a little bit when you go that high. I think this 140 degrees.
    I did not move the character in the game at all. All I did was drop the console and change the fov setting. The green square shows you what you can see with a 90 degree fov. You can verify it with the first pic. As you can tell, the wider angle allows you to see quite a bit more of what's above, below and to the sides of the camera. That's why many people prefer wide angle for helmet cameras. The down side is the curvature of the image. Things out in front appear farther away and things to the side have the fish bowl effect.
    It's a trade off. Much larger field of vision with a bit of curvature to the image or, much smaller field of vision with no curvature at all.
    Edit: here's a still image taken with a gopro to illustrate the same point. With a 90 degree field of view you'd only see what's in the green square (but it would be larger with absolutely no curvature).
    May 2007
    oroville ,,ca
    72
    That's pretty damn good! You just saved me 300 bux!! Now I can put camera in my trex 500 and do some FPV flying around the neighborhood! Thanks!
    cox's Avatar
    cox is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2009
    Edmonton alberta canada
    552
    good job with the pics, perfect example.....
    R.I.P. Yamahondaman
    Still practicing my NoobiX cube, take it easy on me...
    1982 Yamaha YT175J ( Not much left but the 's)
    1982 Yamaha YT175J
    1983 Yamaha YT125K + 175J =
    1984 ATC 200ES BR - running again - Camchain noise holding me back....
    1984 ATC70 -SOLD-
    Masshole
    2,191
    Quote Originally Posted by DeePa View Post
    Nice!
    We will have to see if i can fall onto a pond again
    May 2007
    oroville ,,ca
    72
    , is that a Cell phone or a GPS on the handle bars? TTT
  15. #30
    Phoenix, AZ.
    6,719
    Garmin Legend Cx GPS. Not that I know how to work it.
