Thread: 250sarmx swing
    t-3 is offline New to the board Arm chair racerNew to the board
    Oct 2009
    southern illinois
    18
    250sarmx swing
    any tips on getting rear swingarm off 250sx. do i need to purchase a special wrench for rh side nut with 4 notches in it or will a and punch work. center allen bolt is super tight as well. any help would be appreciated.
    racerxxx's Avatar
    racerxxx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Pennsylvania
    383
    Soak for a few days with penetrant, then I used a punch and .
    1985 Honda 125M (My first Trike--Still have it)
    1986 Honda 250SX
    1981 Honda 110
    1982 Honda 110
    1986 Yamaha YFM80 (Sons quad)
    Past rides: 1983, 1984 200X, 3--1985 Kawasaki T-3
    1987 CR-80, 70's vintage XR75, RM 370
    Pensacola, Florida
    124
    Quote Originally Posted by racerxxx View Post
    Hammer and punch for me also.
    Avatar: 1986 250SX with a 350x front end. Almost done.
    Feedback thread: http://www.3wheelerworld.com/showthr...-for-Coaltrain
    Jun 2003
    Anchorage/Homer, Alaska
    480
    I bought the correct tool from my local Honda shop; I don't recall it being that expensive. I've seen too much stuff destroyed by using the wrong tool. If that punch slips you could easily damage the threads in there. You could make your own tool using a piece of pipe and cut out the notches in it.
    Also, use a 17mm allen socket in that center bolt. Someone recently posted pics of a nut stuck in theirs. Someone probably threaded the nut on a bolt to loosen the center bolt; instead the nut got stuck.
    1985 ATC 250ES, Big Red
    1984 ATC 125M's, 1.5 of 'em
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
