I was / am looking to make a high performance clutch kit on the 250es that will allow the engine to rev a little higher before it engages allowing my 27 inch zillas to get spinning a bit better in the mud.
I can adjust the clutch to where I can lift up on the shifter from nuetral and hold it there while I rev the motor and then let the shifter go into first gear allowing the tireas to spin. Sort of like popping the clutch.
What is ya'lls opinion of doing this?
Keep in mind I have a high comp piston and cam.
