Results 1 to 8 of 8
Thread: Tecate shock linkage
    85Tecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Iowa
    442
    Am wondering if the adjustable shock linkage (I believe its from an 86/87) is a direct swap to the 85?
    It does fit. You have to do a little shimming with a couple big washers because the 86 link is a little bit narrower than the 85. I run an 86 in my 85.
    Mar 2009
    Iowa
    442
    Thanks alot! Now i gotta find one
    Apr 2002
    s.w. michigan
    6,498
    Yep, I run one also on my 84/85
    I used this one on the stock steel swing arm and now have it on the 86 alu swing arm I currently use on my 84/85 T-3
    Yep, I need to get the locking nuts too. Work using loc tight this season but,,,
    I am thinking I need to adjust mine out farther or use a longer adjusting bolt to put more pre-load on mine using the 300ex.
    I will be playing with that suspension work after I get my 86 alu back from being welded.
    john
    Bartlett TN
    3,083
    Well the adjustable ones for the trx and 250r work for the tecate then? I have one that was on my R and looks just like it. I guess I can go and find out eh hehe.
    86-87 Tecate ROCK!
    Sep 2008
    Northwest Indiana
    550
    I used a kx125 linkage......direct bolt in!
    1985 KXT250 A.K.A. "Doom"/Multiple Engine Combinations/Jason Hall Inverts/HRE Swing Arm, Cal Fab Swing Arm/Jemco Pipe/Buzz Saw Cylinder, Klemm Research Cyinder/PWK Carb/PVL Ignition/Dura Blue Axle/Mosh Custom Seat
    Mar 2009
    Iowa
    442
    Quote Originally Posted by Tecate 50 View Post
    Is it as long as the 86? I want something with alot of adjusment as i want mine to sit as high as possible.
    Sep 2005
    MICHIGAN
    2,027
    one off a 1986 KX250 is longer
    86 T3
    84 T3
    86 KX250
