Results 1 to 12 of 12
Thread: wheel stud removal
    ovhonda1's Avatar
    ovhonda1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2005
    Louisville, KY
    369
    wheel stud removal
    Any tricks to getting the studs out of the hub. I am looking to put longer studs in for extenders.
    I just whack em with a .
    ovhonda1's Avatar
    Sep 2005
    Louisville, KY
    369
    that is exactly what I was thinking, but I like to check before beating the hell out of something. thanks for the reply.
    Jan 2005
    RI
    2,530
    if you want to save them, put the lugnut on first to protect the threads...they are not cheap from honda...like 3 bucks each or so
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Sep 2007
    100mi west of Chicago
    3,582
    How about the studs that thread into a front hub? If you grab them with vise grips you will mess up the threads. Yeah using a rag around them helps but can still mess them up. How do you guys remove these?
    Rob
    Jan 2005
    RI
    2,530
    if youre talking about the studs for the brake rotor, you can pull em out and throw em out, and use bolts, or tighten 2 nuts against each other on the stud and put a 10mm wrench on the bottom nut and it should take the stud out.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Sep 2007
    3,582
    Quote Originally Posted by DeePa View Post
    Never thought of that. I will have to try it out.
    Rob
    Feb 2009
    michigan
    2,387
    just tap out with a ,use a piece of wood if you want to save them
    1985 ATC 250R
    . Team Red Trike
    Aug 2009
    Newfoundland, Canada
    915
    Quote Originally Posted by harryredtrike View Post
    ^ X2 the wood wont ruin the threads
    4cfed's Avatar
    4cfed is offline Just Too Addicted Arm chair racerJust too addicted
    Oct 2009
    wisconsin
    619
    just did this the other night on my 200x... god ol thor removed them.. thor is my bfh mini sledge
    86 200x, 1st gen 200x axle,400ex hubs,fmf megamax2 muffler
    Three wheeler guys probably have the biggest balls out of all the ATV/Motorcycle riders. You just have to be a little twisted to ride them, and you have to be a great rider to do so.
    'let those who slide decide'
    Wood may not always work, thats when a big brass punch is your buddy
    Feb 2008
    Orange County California
    726
    dido, brass punch is the way to go
    1986 ATC250r
    1984 ATC70
