Thread: 14/36 gearing info - my top speed
    scottp597's Avatar
    scottp597 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2009
    Lowell, IN
    153
    Exclamation 14/36 gearing info - my top speed
    My stock 86 250r with 13/39 gears had a top speed of 65mph (using gps). And the gears felt really short. So when I restored mine from the frame up with added power I knew that 14/36 gears would be the answer. And believe me it is
    Switching to 14/36, I did one run which I probably won't do again but the top speed was 85.4mph! with possibly a hair of throttle left. Dangerous? Yes
    Its not all about the top speed, I did it so I could know. The best part is how I don't feel like I have to quickly shift through first and second to get going, the power is well spread out and more easily controlled. The extra power of course helps pull such tall gearing.
    Esr 310 bolt-on, 39mm pwk, esr exhaust and silencer, carbon fiber reeds, esr air box eliminator kit
    Jun 2003
    englishtown NJ
    2,676
    I use 14/36 on my 250r trike also, I find its easier to ride with it and less shifting. I use 18" tires too. I have +1 swinger and lrd 310pv, 39pwk, cr rad valve, cr250 ignition and swap between the atc5 and pt hi-rev pipe. I'm using a 85 bottom end. I don't know how fast it is, but it sure is scary, I hardly ever use 5th and 6th, most of the time, I'm in 3rd and 4th. Most mx tracks don't allow you to open up that much.
    scottp597's Avatar
    Apr 2009
    Lowell, IN
    153
    Quote Originally Posted by deathman53 View Post
    This is defiantly the case. I never even shifted into 5th or 6th ever until I had enough room and could safely see what this would do on top end. I just didn't expect it to add 20mph lol
    85Tecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Iowa
    442
    I heard that going up 1 tooth in the front is equivlant to dropping 5 in the rear.
    Apr 2006
    PA
    1,464
    Quote Originally Posted by 85Tecate View Post
    1t front = roughly 3t in the rear.
