Results 1 to 8 of 8
Thread: Logic Question about Exhaust Pipes
    Apr 2008
    Kalamazoo, Michigan
    814
    If this is a dumb question just let me know, but I am trying to think and it is not working out the best for me.
    I have a PT Hi-Rev pipe for my 250R and its awesome up top, but lacks everywhere else. I want to put a big bore sleeve in my R but i am having a problem thinking about how the exhaust should work.
    If i have a 295 sleeve in my R, and i run the PT Hi-Rev pipe, would i get more mid range? I'm trying to think of the output of air, and at lesser RPM's with a bigger bore = more displacement, so would my PT Hi-Rev pipe be better all around?
    What about a low end pipe in the same aspect?
    If I run my PT-5 pipe with a big bore kit, am i going to lose some mid range, but have enough low end power to pull unborn babies out of fetuses?
    Let me know what your thoughts are and tell me if I'm just crazy.
    Leave feedback for me here : [Please Don't start another thread again!]
    http://www.3wheelerworld.com/showthr...for-MagicJames
    Current :
    86 250SX
    86 350X
    86 250R Project
    Owned and Sold
    85 250R
    2 ATC70's 84 and 79
    Feb 2009
    Rome,NY
    1,046
    It is a dumb question a bore on a stock cylinder gains so little .... a true big bore is 330 that would change the power but in the end a hi rev pipe is just that a high rev pipe ..... so if you want to have more mid range power get a mid range pipe....
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    If you want more low and mid, change your pipe to a mid-range pipe, and maybe a different set of reeds. A PT High Rev pipe is just that, a high rev pipe.
    TF 07,08,09,10,11,12,13,14!
    4cfed's Avatar
    4cfed is offline Just Too Addicted Arm chair racerJust too addicted
    Oct 2009
    wisconsin
    619
    could always run v force 3 reeds... it will help even more with throttle responce/ revving..... what about gettin the cyl ported?? a good porter should be able to port it to your needs, to gain some mid rainge
    86 200x, 1st gen 200x axle,400ex hubs,fmf megamax2 muffler
    Three wheeler guys probably have the biggest balls out of all the ATV/Motorcycle riders. You just have to be a little twisted to ride them, and you have to be a great rider to do so.
    'let those who slide decide'
    na
    5,702
    Dude, you need a ESR atc 5 pipe on stock bore or bigbore, or FMF fatty on a stock bore unported / slight ported 250cc.
    The FMF on a stock machine gives nice low to mid grunt with some top end.
    The midrange is sick on the ESR atc 5 pipe..And with a big bore and hi compression set-up, you should have all the low end you need, but yet, the mid and top end is just rediculous on those pipes.
    I wish I could put my wifes ESR on my ported 250R..
    Hers runs as hard as mine in the midrange, and she is stock with a 36 mil carb.
    Mine has significant changes to the jug and a PWK 38 mil with a FMF fatty.
    But yet hers will pull just as hard as mine,basically stock. Just not as hard on the low end.
    Proudly NOT a member of
    "Team on the Teat"
    Dec 2002
    Orange County, NY
    1,772
    I've always been happy with the overall power my PTR Hi Rev made. I used to ride mine in the woods all the time with that pipe and just some basic bolt-ons without any issues.
    John
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
    Apr 2008
    Kalamazoo, Michigan
    814
    My problem is that when i run the PT Hi Rev, my front tire hits the pipe and now it looks like .
    Current :
    86 250SX
    86 350X
    86 250R Project
    Owned and Sold
    85 250R
    2 ATC70's 84 and 79
    Dec 2002
    Orange County, NY
    1,772
    Mine only did it when I had the bike slammed for the ice and I would catch a big bump like when you'd overshoot a turn and jump the berm. I fixed it by going to a 22" tire.
    1986 Monstecate
    1984 ATC125M
