Thread: need help with clutch
    May 2009
    wa
    6
    i have a 84 110 atc and im trying to get the clutch off. how do i get it off? and what can i do to keep the clutch from spinning?
    Apr 2008
    NW, IND.
    842
    Get a manual!
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Apr 2009
    Saskatchewan
    119
    If you mean the centrifugal clutch they usually have a left hand thread nut at least the 200 does can't say for sure on a 110. Using an impact gun should spin it off easy. Should be a 30mm socket.
    6,804
    Its a special socket with 4 prongs to remove the clutch nut and the easiest way I have found to remove it is with a Air Impact . Their is a special large Honda clutch wrench that holds the clutch while removing the nut but I never felt the need for one .
