Results 1 to 3 of 3
Thread: 200x starting problem
    Mar 2004
    Fond du lac,WI
    658
    my 86 200x was running and starting fine until today...it will only fire a little bit with the kicksart an then die the only way i cant get it running right is pushing it down a hill then popping it in gear then when it runs its backfireing alot and burns oil pretty bad i know its not the carb beacause i put it on my other 200x and it runs fine so could this all be due to low compression? my other question is i have a 85 200x would the motor off that bolt up to the 86??
    6,807
    The motors dont interchange between the 85/86 their a totally different set up . your 86 sounds like it jumped a tooth on the timing and for the smoking you probably need the top end rebuilt .
    Mar 2004
    Fond du lac,WI
    658
    what all can be swaped over....because the 85 needs new axle bearing and the shock is bad and the seat and tank are shot so would those things swap over
