Results 1 to 15 of 17
Thread: neutal indicator
    Aug 2003
    neutal indicator
    Does anyone know how to bypass the neutal indicator for a KLT 250 or where I could find a schematic for this?
    roger86200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2003
    Western New York (Buffalo)
    348
    why would you want to? what does it harm?
    1984 Honda ATC 250r
    Bored .020 over Wiseco, Answer silencer, fresh motor, New connecting rod and balanced crank, Boyesen 2 stage power reeds
    Aug 2003
    I think that is why it wont start. Before it stopped working it started fine. Now you have to use a screwdriver to start it.
    Aug 2003
    Jul 2003
    348
    what do you have 2 do with the screwdriver? im lost lol....
    1984 Honda ATC 250r
    Aug 2003
    I started to have problems with it not starting. The start button isnt working any more and have to touch the little screws to get it to start. The screws that I am talking about are the screws to activate the solenoid. One guy asked me if I had a neutal indicator because he has seen alot of people have that same problem. THat is why I am asking. Might it be a wire or is it the indicator? Any help would be awsome. I am lost right now. If it is a indicator can I get a new one or can I just bypass it like I asked you? And How??
    Jun 2003
    Lake George, New York
    1,732
    Try bypassing it then. Or try to get a new unit.
    Jul 2003
    348
    bypass it... you should be able to just bypass the sensor... it thinks its not in neutral and it wont start is what im gathering.... so you should be able to fond the wires coming from it and just cross them possibly
    1984 Honda ATC 250r
    KLT Problem
    Dang, I forgot all about the electric neutral indicator. It does act as a "safety" switch to keep you from starting in in gear. Roger and Cam are right...it should not be a problem to just take the indicator out of the system. How you de-activate it depends on how it's wired up, and how the indicator works. You'll either have to jumper the 2 wires together, or leave them open.
    By the way, I have an early 80's KZ/KLT 250 motor. Haven't had it all the way apart, but so far it looks like it will be good for parts, or maybe even for build. Have a few other parts too.
    83 185s *Now belongs to my nephew*
    83/84 200x
    85 Tri-Z
    85 350X
    85 Tri-Z Parts Donor
    88 Yamaha Moto-4
    Oops!!
    Sorry about the second post, but I forgot something. Try going to buykawasaki.com. I know they have parts schematics with part numbers, etc. for your Prairie, but not sure about wiring schematics.
    83/84 200x
    85 Tri-Z
    85 350X
    88 Yamaha Moto-4
    TRI Z Racer's Avatar
    TRI Z Racer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2002
    Boscawen, NH
    342
    maybe its a bad solenoid all together, when you press the start button do you hear the solenoid click? or do you hear nothing. if you here it click but nothing happens, its a bad solenoid. My geuss is that if the wheeler is in nuetral and the light is on, and when in gear the light is off at the handlebars then the nuetral safety switch should be good. try checking the fuse on the solenoid also
    1985 Yamaha Tri Z 260PV
    Suzuki Trail Buddy 50
    Jun 2003
    1,732
    Isnt cyleniod spelled like that
    spelling
    No Cam, Daniel Webster says it's solenoid.
    83/84 200x
    85 Tri-Z
    85 350X
    88 Yamaha Moto-4
    Jun 2003
    1,732
    Huh. well he should eat my dust!
    Aug 2003
    Tore apart the bike last night and tried to find out where to bypass the switch with no luck. Anyone have any ideas on where to look and how to bypass it? Could the ignition modual be bad and if it is would the bike still start by touching the relay with a screwdriver.
