Results 1 to 8 of 8
Thread: C.D.I box ???
    Jun 2003
    North Dakota
    54
    C.D.I box ???
    if the cdi box is bad would that cause it to run bad at wide open or would it do it all the time say at midd range.
    86 350x
    85 250sx
    84 200m
    79 110
    May 2003
    Shediac, New Brunswick
    1,126
    re:
    I am not sure but I think if the CDI is bad that the trike would not start. anybody correct me if I am wrong.
    Apr 2002
    s.w. michigan
    6,498
    my 2 cents worth
    from what i've seen in the honda manuals is that weak spark or no spark,,,,,, check and or replace cdi box.
    i have had coils cut out at higher rpm,,,,
    that's about it for me + my input,,,,
    john
    your C.D.I. box eother works or does not. there is no inbetween
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by MR ATC
    Actually I had a 350x that ran like crap. The only thing we replaced was the CDI box and it ran great. It would idle but would act like it was only firing 1/2 the time when you gave it gas. I have only ever seen this one like this. All the others I have ever seen bad was like MRATC said. They didn't work at all.
    Howdy
    Jun 2003
    North Dakota
    54
    im going to try my friends cdi and see if that will work
    86 350x
    85 250sx
    84 200m
    79 110
    TG is offline New to the board Arm chair racerNew to the board
    Jul 2003
    23
    CDi fault at high speeds
    Yes, it definitely can, not from an outright failure, but due to weakness and/or vibration. The ignitions naturally lose power as speed climbs and any losses aggrivate it at high speed.
    Rittman, Ohio
    6,276
    A CDI problem is nearly impossible to diagnose because of the wide range of symptoms. They rarely fail so they are usually the last resort, and you only find out by swapping it out. A guy here has a Banshee that would idle fine, but start breaking up badly every time he gave it any throttle. He struggle with this for a long time, and as a last resort, borrowed a CDI to try, and problem was solved.
