I've read several threads on removing the flywheel so the stator can be removed from an 85 Z and it seems you need a special tool to do this. The manual doesn't go into detail on this issues as I can see. Once I removed the cover it seems the only thing holding the flywheel on is a nut about 20mm in size (if it's metric ). That bolt does have to come off doesn't it and in a lefty loosey turn. Or do you still need the tool once the nut is off? I just don't want to screw up any of the parts or screws when I do this. If I need the special wrench then I'll hold up til I can get one.
Thanks.
