Results 1 to 11 of 11
Thread: Safe to use WD-40 on......
    Oct 2009
    Tucson, Arizona
    90
    I was just wondering if its ok to use wd-40 to clean my engine? I sprayed some on a cloth and it seem to to clear up a spot on the motor that was dingy. I sprayed a little on the front part of the exhuast pipe to remove some rust. It took off the rust real good, but I had started the bike and it started to smoke where I put the wd-40 on the exhuast pipe, is that normal?
    bad350's Avatar
    bad350 is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    kentucky
    176
    normal? yes oil will burn when it gets hot
    I spray down my entire machines after they get a bath.
    Phoenix, AZ.
    6,719
    I soak everything metal in WD40 (except brake rotors) after every wash. It will smoke when you start it but not for long.
    85Tecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Iowa
    442
    Only bad thing is it will draw dust. But if you do alot of muddy riding it will actually help the mud not to stick as bad. I spray mine down with it. I dont mind a little dust.
    Aug 2009
    Newfoundland, Canada
    915
    and when it burns off, it makes a nice smell! at least I think so
    Mar 2004
    Fond du lac,WI
    658
    anything you put on your motor will burn off when you start it. just like when you spill a lil oil on your motor
    Nov 2009
    Ashland Wisconsin
    54
    wd40 might make it look good but dont go driving on some dirt roads or anything the dust will stick to the wheeler like a dust magnet
    Feb 2008
    Melrose, Florida
    9
    Most every motocross and harescramble rider I know sprays their bikes with WD40. The rubber hoses are sprayed with silicone and plastics with SC 1 or whatever you like. WD40 keeps your metal and aluminum protected and shiny but does collect dust. WD40 will also clean scuff marks off your plastics and graphics.I don't spray my bike if I'm going to ride within the week. If I do I'll clean it with simple green and wash my bike off before I ride. Then clean the rotors with brake cleaner.
    Oct 2009
    Tucson, Arizona
    90
    Thanks for the help!
    Williamstown PA
    5,825
    i use it but i use a solition i mix then to clean it off so it does not attract dust.
    use a little pomolive dish soap and fill a spray bottle up shake well and spray down what ever you sprayed with wd40.
    i clean all my parts this with with process. stuff gets a nice protective coating on then.
