Thread: Neutral Indicator Light - Rig won't start
    Nov 2009
    Central WI
    Arrow Neutral Indicator Light - Rig won't start
    Hey Everyone! I have a 1984 - 200 ES Big Red that ran about 1.5 years ago and then it mysteriously quit working...I have pulled the plug and replaced, cleaned the tank out of what ever was left along with the fuel filter in the tank, sprayed the carb out with cleaner and replaced the decayed air filter...I have tried and tried to pull start this rig because the battery was dead but since put the charger on the battery and noticed the Reverse and Neutral indicator lights no longer illuminate...Any help on what may have caused this once dependable rig to no longer run????
    racerxxx's Avatar
    racerxxx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Pennsylvania
    383
    Check connections at neutral start switch, had the same problem with my 250sx, I'd assume that there is one on the 200 as well so you can't start in gear. Mine was on the right side of the motor down by the foot peg. Also check your fuses.
    1985 Honda 125M (My first Trike--Still have it)
    1986 Honda 250SX
    1981 Honda 110
    1982 Honda 110
    1986 Yamaha YFM80 (Sons quad)
    Past rides: 1983, 1984 200X, 3--1985 Kawasaki T-3
    1987 CR-80, 70's vintage XR75, RM 370
    85Tecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Iowa
    442
    Quote Originally Posted by racerxxx View Post
    +1 9 times out of 10 its these connections. There will be a small cover i believe and 2 sensors in there.
    Mar 2008
    EastGreenbush, newyork
    3,494
    Probably a loose connection. are your batery connections tight?
    Nov 2009
    Central WI
    Battery is dead
    I was using my battery charger to get me power through the dead battery. I just don't know if these lights absolutely need to be powered or will the machine fire without??? I have power to the head light and when I hit the starter switch it just doesn't seem to have enough juice to get the starter to turn over....Yet, as I think back to my attempts the head light has a very strong beam...????
