do you need one to run lights? i have a ricky stator flywheel and stator. the tail light works. i'm going to hook up headlights and don't want to blow them out.
Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
My Feedback
http://www.3wheelerworld.com/showthr...k-for-sblt500r
first gens don't have a voltage regulator
its an open system. the range tops out at 17 volts. 12-17ish depending on RPM
Shawn,you need to swap out the lighting coil on the stator.The ricky setup uses an 80watt but they also sell a 65watt which won't blow your lights.Thats what I did for my standard lights setup and it's fine.They sell for $39 on their website and if I remember rightly it's only a case of soldering 2 wires.Nice build by the way,absolutley awesome.
I got the Ricky Stator and the flywheel combo on mine and I was told that you had to use a regulator. I think it was 20 bucks and all is well so far. This is on my 86.
Use the regulator.
"You should never smoke in pajamas..
You might start a fire and burn your face..
Maybe you should return to Manaugua..
You could go un-noticed in such a place"
FZ
Ass,gas or grass....nobody rides for free!
Ride free,Brotha. See you in Heaven.
My Feedback
will any regulator work? i have a bunch of lt250r regulators.
My Feedback
I doubt any regulator will work. If youre going to run lights, yes use a regulator.
