Results 1 to 15 of 17
Thread: Tri-Moto 175 Restoration
    3WheelHouston is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2002
    282
    I have a tri-moto 175 that I'm about to start restoring. I've had it for a while but I'm just now ready and motivated to start. It's supposed to have run quite well, but needed a pull starter and brakes. And then it sat outside for 2 years or more. It has an overbore piston, but other than that I'm not sure how it's been modded. But it's said to be fast. I wanna get it working though so I can have three working trikes to ride, and two more I have access to. What sitting-related problems should I look for when starting on it friday? Also what gas/oil mix? What kind of oil? This will be my first two stroke project, so anything else I need to know would be helpful. -Aaron
    It ain't no fun unless you kin git hurt doin it.
    Rides: YTM-225DX, 2x YTM-175, KLT-160, ATC-125M, ATC-250SX, ATC-200x, ATC-200E
    Tri-Z dude is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    i have a 1983 tri moto 175 and im rebuilding it fro motor to the outside
    i have parts comin from new zealand hopefuly
    all i have is a motor fram(bent) rear plastic and seat and whole rear end and thats all i have anyway
    could you post a pic of your trike so i can kinda study it
    thanks
    Ben
    1982 Honda 200
    1984 yamaha 225DX
    1984 yamaha 225DX parts bike
    1986 Honda cr250r (soon to be trike)
    Howdy's Avatar
    Celina, Ohio
    10,079
    I have a 175 parts machine. I plan on e-baying it in the near future ( in parts ). I have the pull starter, good frame, f/forks, rear plastic, a rough bottom end, and a few other parts. No gas tank or top end of the motor though. If interested in any parts before ebay make a me offer for them. They are on the schedule to be ebayed in 2-3 weeks depending on when I get pictures and such.
    Ithaca, NY
    2,596
    hey houston, I did a 175 in january-February of this year. I can help you. I have tons of pics of the resto. here is what it looked like when I bought it
    for 20 bucks. I had to hunt parts all over the place, and modify the front brake cable to fit. ( I bought 3 from different suppliers and none fit right!) As far as fast......mine has a new top end with a DG head, and a white bros. pipe and silencer, HD clutch springs and clutch. I polished the intake and exhaust ever so slightly, rebuilt the carb, and it was so scary fast, my wife, who I built it for, wont ride it! It smoked my 86 200x with ease. Lots of fun with no suspension, I like to refer to it as "the most dangerous vehicle ever built", especially when the front wheel comes up in 3rd gear, for no apparent reason! You will love this thing. I run the oil injector with Bombardier snowmobile injector oil.
    Haspin veteran '02, '03, '04, '05
    "Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
    RECOVERING Trikeaholic
    Ithaca, NY
    2,596
    here is the DG head and pipe pic
    Ithaca, NY
    2,596
    hereis the pipe
    Ithaca, NY
    2,596
    here is the completed project
    Apr 2002
    282
    Hey, I take it that's new plastic? Where from? And the brake cables? Also, where did you get the pipe? Mine is stock. And I can't wait to get this thing running Mine already has some lower profile wider rear tires on the back. Fast and dangerous is just my style. I bet this thing would make a hell of a flat tracker. Hey howdy I'd like the pull starter and brake lines if you have them. I'm not sure what to offer so what's the asking price? Email me K2sk8r413@aol.com
    Ithaca, NY
    2,596
    that is not new plastic! it was wet sanded to bring out the shine. The headlight shell was painted white when I got it, and I wet sanded it and then waxed all the plastic. The rear fenders it came with were so smashed up, I was lucky to find a set on ebay of the same year and decal color, just faded a little, so I wet sanded that and waxed it. The fenders for the rear were $15 on ebay, and I was the only bidder. As for the pipe I got it from Rman, remember him?? The brake cables I bought from dennis kirk, the rear takes 2 cables, one for the hand brake, and one for the foot brake. One of the cables is unavailable, so I hung it up and put an oil drip to it, that loosened it up good, I also put a heavier return spring out back(hardware store special) and the front cable--the problem is all the aftermarket replacements dont have a long enough threaded portion to reach the brake arm, know what I mean? so, I was able to get a 6mm couplling nut from work (I work in Industrial supply) and attatch it to the cables threaded portion (where the wing nut usually goes) and then come thru the barrel on the brake arm with a Socket Head cap screw 6mm X 80, now I can adjust the brakes still, and it is working great. I can probly get you a nut when you are ready. PM me and I will give you the info
    Sioux City, IA
    256
    I can get you new stuff around 15% under MSRP. Just ask. Its better if you buy the big items because the discount will be greater, ess shipping costs. Yada yada yada.
    i need ALOT of parts to complete my restoration on my tri moto 175
    can you hook me up with some of those parts
    thanx
    Ben
    1982 Honda 200
    1984 yamaha 225DX
    Sioux City, IA
    256
    Brakes will cost around $26.00 and the 100% complete brand new pull starter would $142.50 :? . Check out partsfish.com to find what parts you would like. Sounds like it would be wise to talk to Howdy if you want to get that pullstarter for alot less. Always fun to deal with Howdy. :-P Its hard to turn a buck on Yamaha parts. Honda ones have a HUGE markup and makes it easier. Yamaha plastic is cheap compared to even maier pieces. Crap, I can get you new rear fenders for $90 :shock:
    Ithaca, NY
    2,596
    i think the yamaha plastic is discontinued, I believe we looked into it before. I cant remember so I could be wrong. I just checked my parts box, and I have an oil tank, some really bad footpegs, a fuel pump.
    Sioux City, IA
    256
    They have a parts # and price listed for them still. Usually they'll have the pic but no price if they've pulled that part. But then again, I've never tried to get some.
    hey trikeoholic
    will you send pics of oil tank and gas pump
    thanx
    Ben
    1982 Honda 200
    1984 yamaha 225DX
