OK, to make it run you need fuel, spark and air. Have you tried a little starting fluid in the cylinder and then pull starting? Just cause the carb is clean doesn't mean fuel is getting in the cylinder. Is the fuel valve open? Is your air filter clean. You must run with a clean airfilter. If you run with a dirty air filter it won't get enough air to fire. Also running without an air filter is bad since it will cause the trike to run lean and it will over rev. If it revs out and the kill swtich won't kill it, you will have to pull the plug wire off the plug! Have a rubber glove handy or you will get the cheap thrill of your life as you get zapped really good!!!!! But I would make sure you are getting fuel into your cylinder first.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
