Results 1 to 3 of 3
Thread: Brought home another trike 84 big red
    az
    2,001
    Never had a shaft drive, anything to look out for? its been sitting for years. complete, I need to swap the front tire, flush the tank and clean the carb. Seats good, has front and rear rack. Gotta get a battery too. But for 200 bucks. I think im happy.
    So anything to watch for on these things? the guy has a 185S that Im hoping to pick up later in the week. jim
    81 185s
    82 185s with 85 200s motor
    82 185s
    and a 72 ct70
    ilmoakw is offline At The Back Of The Pack Arm chair racerFirst time rider
    moncton
    244
    $200.00 is a good deal. The only thing I would check is the oil in the rear end. Sometimes the boot where the drive shaft meets the engine gets torn and allows water/mud/crud to flow into the rear end. Other than that these things are tanks!
    85Tecate is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2009
    Iowa
    442
    As long as you keep gear lube in the rear end and check it for water periodically you shouldnt have a problem with them. Those rear ends will take some abuse!
