Well Mike just pointed out that I have an auto cam chain adjuster..........SO looks like itll NEED to be torn down just to do the cam chain so Im probobly gonna do a top end rebuild...Is there a kit to do this with all gaskets, seals, parts?
TRIKES:
1985 Yamaha YTM 225 DR Special Edition
Dirt Bikes:
2006 Honda CRF 250R
SLEDS:
2001 Ski Doo MXZ 600
1997 Ski Doo MXZ 583
dennis kirk has the gaskets for the top end ,piston/ring idk bout seals though..also im sure egay has everything
1985 Quad Killer
1985 Mini Raag
1985 Green Gobbin X2!!
1990 Kawasaki 300sx
R.I.P
You say it smokes? Maybe its piston slap?
Rides
85 ATC350X
85 ATC200X
What causes a piston slap? How do tell how big my current bore is?
TRIKES:
Dirt Bikes:
2006 Honda CRF 250R
SLEDS:
A topend thats worn enough will make piston slap. Its exactly what it sounds like, the piston slaping around in the cylinder.
I would also do the cam chain as everyone else said. It would suck to install a new piston kit and have to tear it back apart for the chain.
You can in most cases pull the head and find marking or numbers on top of the piston to tell the current bore size. You will need a over sized bore piston kit. I'd pull the cylinder and take it to a local machine shop and have them look at it to find the current size and what size kit you need.
Rides
85 ATC350X
85 ATC200X
How can you tell if the piston slapped? Is the cylinder all scrattched up. Im definately gonna do a ring/valve/chain job over the winter just need to get some cash amd need more garage space lol
TRIKES:
Dirt Bikes:
2006 Honda CRF 250R
SLEDS:
I would say it is the timing chain I had the same problem on a 400 ex.
Milkman took the words out of my mouth.
These old machines need timing chains AND sometimes tensioners.
I'm not educated on a Yamaha auto or manual tensioners, but they just hold something in place. They DON'T do much work, but the timing chain and gears sure do.....
I must admit, I almost never find worn TC gears, just a worn and stretched chain from doing it's job for 25 years.....
Ok time for an update...I went and got the impact screwdriver 85Tecate was talking about and got the cam cover off. One snapped halfway off so ill have to drill and tap that one not a big deal. So I was wondering how to tell the cam chain is too loose it feels pretty snug with some pay but it doent fell terrible. is it supposed to be tight
TRIKES:
Dirt Bikes:
2006 Honda CRF 250R
SLEDS:
order an impact screwdriver set from sears not harbor freight. thise HF ones snap the tip soff easly. the craftsman will last you for years!! I've used mine a ton on trike rebuilding and brake jobs. so that's really your best bet.
________________
https://www.mikesatvfix.com
________________
Yea I know I wasnt gonna adjust it i just wanted to see if that could be a problem im definately gonna rebuild it and replace the chain and sprockets aand top end so Im gonna start tearing it down hopefully tomorrwo
TRIKES:
Dirt Bikes:
2006 Honda CRF 250R
SLEDS:
