Results 1 to 12 of 12
Thread: 350x death wobble
    Aug 2009
    Kansas
    16
    350x death wobble
    Anybody got suggestions on what maybe causing the front end on my newly aquired 350x to shake? thanks
    Apr 2008
    somerset ma
    1,822
    check the bearrings, they might be bad. if you're riding on the street, the front tire just might not be ballanced. mine does it too on the street
    Mar 2008
    EastGreenbush, newyork
    3,494
    on pavement, you will feel all kinds of wobbles you wouldnt on dirt. But if its rael bad you might have a bearing issue, or a tweaked front axle. could be a number of things, but thats what I would check first. Also could just have a flat spot on the tire from sitting.
    eyecekold1's Avatar
    eyecekold1 is offline Check my feedback before buying from me First time rider
    Oct 2009
    Provo Utah
    209
    I think the same thing... bearings. Does the back end wobble when its sitting still, like if you shake the bike using the grab bar? If you can see movement where the axle goes into the carrier its your bearings. Thats all I got. Good luck.
    85 350x 12:1 piston and porting by "boosted96cobra"
    4 85 tecates 1 runs
    5 84 tecates none run
    1 84 Yamaha Zinger, mildly ported & polished, milled, bored .25 over finally running
    2 atc 90's just parts bikes
    00 rm250
    93 kx500
    2 Honda 200m parts bikes
    Nov 2009
    Ashland Wisconsin
    54
    Broken Belt In TIre???
    Aug 2009
    Kansas
    16
    I think the guy I bought the trike from may have put that green slim crap in the tires. He told me he put it in the rear tires ( I didn't tell him how excited I was that he had done that.) I think that crap should be outlawed. Tread wise it looks like a pretty good tire, there is one plug in it. You guys should see this trike it is so ugly. LOL its all factory 86 colors with yellow front and rear plastic. Its not even painted plastic its actually yellow. Red, white, blue, yellow with black fork boots and silver wheels. This thing would fit right in at a gay pride parade. Any you guys think that tire sealent crap would make the trike wobble like a PBR bull?
    3 or die's Avatar
    3 or die is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2004
    southeast
    198
    It might help to put more air than usual in the tires. Seems like I can find worn stuff eaiser that way
    I run slime on my 350X Holeshots, glad I do...........
    No wobble hear at all............
    If the rear axle AND hubs are spot on, bent rim??
    Did ya jack it up, rev it up and watch the rear tires??
    Sometimes fired up steering stem bearings make the back feel all fired up................
    bent forks?.... bent rotor..
    Escanabajosh's Avatar
    Escanabajosh is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    U.P. (upper michigan)
    352
    i had the same thing with my sx when i first bought it, the front tire wobbled like crazy. the first ride i took it on ( just down the road a mile and back) and my arms hurt from trying to keep it from wobbling ( i was on a paved road). replaced the front wheel bearing and now i can go 5th gear on the same road with no wobble.
    not sure on the x but my sx was around $30 for bearings and seals from the honda shop.
    Dec 2002
    Orange County, NY
    1,772
    Too much slime will give you a wicked vibration. I would break the tires off the rims first to eliminate the problems that are free to fix before I started looking at other stuff.
    John
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
    Mar 2007
    Texas
    5,045
    hey hey now! slime is awesome! it's the best stuff on earth that got better!!!
    all jokes asside, that stuff really is good stuff. not sure why you don't like it. ok you can't "patch" a tire after using it, but if you ride a lot, your going to get a ton of sticks and thorns in the tires and slime keeps you riding w/o issues. (trail and feild riding, track is different). if I didn't run slime all my tires on both kids quads and my 2 trikes would be flat after 1 day if ruding on the trails. Thorn vines, small sharp sticks and stumps all can put a small hole on a tire. the rune of thumb is if it's too big for slim, then you plug it, if it's too big to plug, get a new tire.
    ________________
    https://www.mikesatvfix.com
