Results 1 to 9 of 9
Thread: atc ratio change help
    Nov 2009
    australia
    9
    Gday guys ,i have a honda atc 200e 1982,ive worked the engine a bit and now find it tops out in top gear really easy,can I get a 12 or 13 tooth front sprocket,std is 11.Its not just a flat sprocket but a splined part about 3 or 4 inches long.Also who regrinds cams for thes babys.Thanks Gary
    Nov 2009
    australia
    9
    Is a 12 avalable ?
    if you go up one tooth on the front... its like going almost 3 teeth smaller.. on the rear.
    Nov 2009
    australia
    9
    Anyone know if they are avalable?
    Nov 2009
    australia
    9
    Nov 2009
    australia
    9
    Guys anyone.
    Side Wayz's Avatar
    Side Wayz is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2009
    S. Jersey
    279
    can't you just take a 12 tooth from a 200x and put it on. or change the rear to a smaller size. I just went to a 13front 40 back then switched it to 12 front 35 rear today. Try ebay and call a couple of bike shops thats how i got my 35 tooth rear.
    Ill ask and let u know.
    Aint' no wayz like side wayz!!!
    84 200X (SOLD)
    84 250R #17 AirCooler Current Racer
    85 250R (in progress parts needed)
    Nov 2009
    australia
    9
    Wish it was that easy,its not a flat sprocket.
    Nov 2009
    australia
    9
    Take it thats a no,thanks for you comments.
